Yogi-Gersh
- Jan 27, 2013
Alright, let me first start by saying that I don't speak the "hi-fi language" but I do consider myself to have an excellent ear for accuracy.
The machine sounds awesome, but I must admit that I struggled the first few days to find a connection set-up that did not result in a harsh clipping/screeching noise. I scoured the message boards looking for a fix, but could not find one.... I told myself if/when I find out how to fix this, I would share it on this message board for anyone else that needed help.
The bulk of the discussion on these boards seems to be about it's sound quality, which it definitely fantastic! However, one potential downside that I've found, and I believe I've since fixed, is the set-up:
For example, when I connected HDMI cables from my Direct TV and Apple TV directly into the DAC, and then used the HDMI out to the TV, I consistently had error/sound problems, almost like a sonic boom noise.... by using the DAC remote to switch from Direct TV to Apple TV is NOT the way to go (I also must tell you that my LG TV is about six years old, so that could also have something to do with my problems). .... the fix is when I went HDMI from Apple TV into DAC, with HDMI out from DAC into TV, then used a optical cable from my Direct TV into my DAC, and RCA from DAC straight into TV.... this creates an extra step to switch from back and forth (now you need to use the source button on your TV), but this definitely fixed my sound errors. You still need to change the source on the DAC, obviously, but you should also need to change the source on your TV....
Weeks later I hooked up a Wadia docking station into the DAC... which sounds awesome. HOWEVER, if you decide to do this, I found that if I didn't take the ipod/iphone out of the docking station while trying to watching Apple TV, those same booming error noises would occur. If I took the ipod out of the Wadia, then Apple TV sounded perfect.
Bottom line, I LOVE this DAC, but I did go through some big growing pains to get there.... hopefully this post will help anyone else that may be experiencing problems, or if you're about to buy one, to avoid them all together.
I welcome any comments/questions.
Josh
Josh
