Hi guys,
to get a comparision as close to the M51 processing I decided to fit the EE min max plus with some LME 49720/LME 49710 and see whether it was worth keeping and or sell off. To my surprise the EE mini max dac was so hard to distinguish to the M51. It made me wonder that if I had the LME opamps in place and not the ADA 4610 brz I would have never had bought the M51.
Oh well you live and learn.
The EE min max dac plus was so close that I had to really close my eyes and do some really critical listening.
The EE is a lot easier to listen to with its laid back nature but the microdetails are all there. Voices are airy and emphasised but has this glary glassy presentation. The M51 is not laid back and is very forward in its nature, the microdetails are also there but the voices are wider and more realistic in its presentation. The mids to low mids are to die for on the M51, cant live without it
. The EE mini max dac is a little reserve and less detail in the very bottom end, it comes across clear and loud with a lot of warm cuddly feelings. The M51 had the ability to separate sound components and present them in its natural sound signiture even in very complex passages, so the M51 wins. The EE mini max plus is so close, if I were to walk into the room I believe I couldnt tell which one is playing, but in an accidental twist I happen to set the setting on the remote and picked that the EE min max was on before I knew the remote was on a non select state.
Before this excercise I was planning on letting go the EE min max plus, but after this excersise I decided to keep it, because this dac has thru the hole components unlike the M51 that are all SMD, very hard to modify!
I reckon if I change some capacitors in the audio signal I can get this dac even closer to SQ compared to the M51
I also think that Im done with searching for the perfect dac, when you almost got an identical analog section ( the LME 47910 is very simular to the LME 49990) and things begin to sound that close I dont think that the digital conversion matters any more. I have the LME 49990 but didnt use them because they are not as stable as the LME 48720/10, This will be my next step and I'll report back.
This post is to share my findings and thoughts and hope it helps on your audiophile journey!
