How would you describe the difference in sq between standard and balanced output?
Mytek Brooklyn Thread
- Thread starter watchdog507
I really only use my Brooklyn DAC+ in my 2 channel speaker setup...I rarely use headphones. My un-audiophile description of the difference would be wider, fuller, as well as louder.
- Apr 26, 2016
I would say after going balanced, the soundstage became tad wider and stereo separation was a bit better. It sounded a little more open/better overall.
Emmanuel Palmer
Am interested in this answer tooHow would you describe the difference in sq between standard and balanced output?
Dobrescu George
Reviewer: AudiophileHeaven
I love the way I can use Brooklyn DAC+ with virtually any headphone
Planars? No worries
Mastering Headphones? Works wonders
IEMs? Sounds awesome
Custom IEMs? Even better
That being said, I did pair Adam Audio PRO SP-5 with Mytek Brooklyn DAC+ and noticed that the sound was way more layered and dynamic than with less interesting DAC/AMPs, really loving this pairing
Also using it with Kennerton Thror right now, and I'm simply blasted away by how natural and clean the pairing sounds
Planars? No worries
Focux
Planars? No worries
don't mind could you share a direct comparison between the Brooklyn DAC+ with the Hugo 2?
Dobrescu George
Yep, sure
I need to get my hands on one first though, will see what I can do about that
I also have Young MK III fromM2Tech in as a DAC, which I can compare with the DAC output of Broolyn DAC+ . Working on that
I've had both. The Hugo 2 is an impressive portable device. Plugged into my Macbook Pro, music sung in a laid back way but conveyed great detail and clarity throughout the range. I did find the amp lacking though and nothing to write home about. The Mytek Brooklyn DAC+ was a revelation for me in comparison. Great detail - maybe more forward in its presentation but dynamics were definitely improved. There was more transparency and separation I thought and there definitely sounded like there was more power and sparkle. My Focal Clears pair much better with the Mytek than the Hugo 2.
Dobrescu George
I made a review where I had a chance to take a photo of Mytek Brooklyn DAC+ with a nice headphone
Man, does the DAC+ look nice and crisp!
Focux
worthy contender then to the RME AD-2 DAC i presume ^
Dobrescu George
I think that most people find Brooklyn DAC+ above Adi-2 DAC
Sound Eq
- Nov 9, 2013
can i ask bout the brooklyn power amp, i see its class D what are the impression of it
Mojo777
- Jan 28, 2007
I think that most people find Brooklyn DAC+ above Adi-2 DAC![]()
Not me. I have both.
Versatility goes to Mytek. RME does a better in upper treble response (tad less glare). They are both amazing and I am keeping both but if I only had digital sources I’d exclusively use the RME.
NickedWicked
Same here, used them both when I still had the LCD-X and the RME was cleaner and more detailed, but the Brooklyn had a really nice warmth and richness to it, slightly more depth as well. Can't go wrong with either honestly.
robjones67
I recently picked up the Brooklyn amp and tended to ignore the classification and look more at the specs and reviews. While everything in my setup is recent and still burning in etc. the amp sounded quite nice and clear both bi-amped to a Marantz 7012 AVR in my HT setup and with the Brooklyn DAC+ in the 2-channel setup. Both driving a pair of MartinLogan Motion 60XT's. Since the ML's are 4ohm they definitely benefited from the extra power. It hasn't been running too hot either like some Class D components.
