Here’s the EQ setting mentioned:
EQ for MYSPHERE 3
My first proposed EQ can be found here:
https://www.head-fi.org/threads/mys...und-design-build-quality.819658/post-16796657
Now it’s time for an updated EQ setting that:
• allows for louder listening,
• has fine-tweaked midrange,
• and features a controlled, punchy bass extension, following Harman down to 50 Hz.
The EQ uses a 51 Hz Hi-Pass (Low Cut) filter with higher Q.
This Q of 1.5 boosts some bass and the cut limits subsonics in favour of a better controlled bass and higher possibly sound level.
The Treble-Shelf-Band is not used (Gain = 0 dB), but frequency and Q are pre-set to adjust treble to taste.
EQ for Mysphere 3 w. B-Pad Band Gain dB F Hz Q Shape B/Bass +6.0 110 0.7 B-shelf adjust to taste 1 n.a. 51 1.5 HP-Filter 2 -10.0 2.2k 2.0 Peak 3 +5.0 2.6k 2.7 Peak 4 -3.5 4.9k 2.9 Peak 5 +7.5 4.2k 1.0 Hi-shelf T/Treble 0.0 4.2k 0.8 Hi-shelf adjust to taste
This is the resulting EQ curve on my RME ADI-2/4 Pro SE:
