germanium
Both are caps. There is a smaller one bypassing a bigger one to extend the high frequency response. I would also like to note these caps are being used exactly the way that lawngnome said not to use them. As you can see so much for his advice on the matter.
Originally Posted by slwiser /img/forum/go_quote.gif My AT amp, AT-HA5000, has DC off-set caps for one of its two sets of inputs and here is a simplified circuit sketch of its layout showing those caps in-line as option 2 above, please note the AC coupled noted just below the AT-HA5000 notation below: ![]() Looking at it closely I am a bit confused by the two parallel items. One is clearly a cap, what is the other? It certainly is not straight wire. |
