tib8
Don't get me wrong, I agree with what you said, it's just that for DIY it's very difficult to make light low resistance membrane. (as you mentioned the lighter you could find is 12um, so it's at least 4-5 times (including the gold) heavier than what we use here. High resistance stators shouldn't be so difficult to create - coating on a non-copper FR4.
Points 5-8 were for my experience with aluminium foil and low resistance stators - which is a terrible combination in my opinion. Capacitance is bigger than normal electrostatic headphones, because now the membrane is in the C equation (high resistance membrane is transparent for the capacitance stator-stator). Humidity was a big problem for me, because of good isolation - when there was a high humidity my ears were shocked with electricity, despite the megaohms resistors I had there.
By the way as I mentioned few times here, I use a different approach with my ES phones - pretty similar to these "inverted" ones.
Thank you for this reply - it has triggered many toughts in me.
I was looking at many of your previous post to find out what was your "inverted" construction exactly. During that I realized that you are (or you were) using a very similar stretching method, which I have discovered lately myself after several trials, and you also use the free air resonance to check membrane tensioning, even the resonance freq is pretty similar, so it is good to see some confirmation that I am on the right track.
Last weekend I have received high voltage cables for my oscilloscope, so I was able to measure my DIY amplifier finally. I was surprised how big harmoic distorsion components appeared at high volume when the input freq passed over 8-10kHz and they increased rapidly with the frequency.
I was surprised because the THD in the spice simulation was very low - BUT that simulation runs on 1kHz! So I repeated the THD simulation on 6kHz, 10kHz and 20kHz, and the simulation was in good correlation with the reality. Then I simulated several popular electrostatic amplifier designs from Kevin Gilmore and from STAX, and all of them showed the same behavior, even with smaller signals.
So lucky this is not my design fault, but it is due to the limitations of HW components. I am still thinking how to minimize this effect, but it has to be accepted that some distorsions are present in every amplifiers.
So back to the main topic: all these classic esl amplifers are symmetric, not single ended. And due to this they tend to cancel out the second harmonic distorsion of the signal and the third harmonic is stronger than the second. On the other hand Nelson Pass (an iconic amp designer) said that he made several experiments what kind distorsions the most people like (or accept more than others), and they find out that the second harmonic should be the biggest component and all higher harmonics should be lower than the previous one. (This is not meaning that you intentionally increase distorsion, but it means that you are trying to archtecture the amp in a way that the reamining small distorsions should follow the rule above.) From this the conclusion is that single ended amplifiers should be used.
So If you don't mind, I will likely try to replicate your completely inverted construction mainly because it can be driven with a single ended amplifier, which I would like to try and compare if it is really better...
