Hi Spritzer,
Thanks for the pictures. Your idea of fitting the Lamda drivers in the frame is interesting. Do you want me to help you make the mounting plates? In order to make them, I need the exact dimensions. Do you think that you can make the measurement for me? What kind of material is good for making such mounting plates? What should be the thickness? How would you fix the Lamda drivers on the plate?
As for mine, I make the mounting plate out of a 5 mm plastic sheet (we call it plastwood here). After fitting everything in, I found out that my mounting plate is a bit too thick. If I were to do it again, I might go with 2-3 mm plate. But, what material is good, I don't know yet.
From your picture, I can see that the dust cover of the driver is actually made of some kind of woven fabric. I suppose this is the side facing out, right? The opposite side must be plastic then.
Wachara C.
