Ulfar4
I am working on my housing for drivers with ear pads and headband. Headband is from Sony MDR7506 and earpads are some 100mm type from ebay. I only need to add some foam to headband for increasing comfort.
Very nice!I am working on my housing for drivers with ear pads and headband. Headband is from Sony MDR7506 and earpads are some 100mm type from ebay. I only need to add some foam to headband for increasing comfort.
Yes, it is from 3D printer (ABS material).Pretty! Are these housings made on 3D printer?
Hi Wachara, I have gone through almost 150 pages of this thread, And although my basic concepts are clear the size and dimensions are getting diverse.
So the question is, which Headphone Driver Size gave you best result?
I am right now making a dremel based diy CNC (Just started), I already own a 3d printer, but lack knowledge in CNC, what milling bit you use for your CNC?
Also I think you said KGSSHV is really good amp. Is there any better and easier to make SS amp than this?
I bought an old Stax amp just to get started with DIY headphones when I stumbled upon Chinsettawong’s blog... I built a KGSSHV after that because the old Stax was noisy as anything! The KGSSHV was great but I was really glad I built the KGSSHV Carbon: more power, cleaner sounds at high volume, my DIY drivers sound louder and cleaner with the newer KGSSHV Carbon... all to say that you should listen to Chinsettawong’s advice. He’s got so much experience with both amps and headphones.
