I am sure their Genesis is made of the same LHHN wire..., just 6 gauge. This also pretty much throws out markl's reviews (build quality of 7 on VD cables, are you kidding? Hot glue and electrical tape?!). This really changes everything. People claim that this cable "sounds" better than cables that are actually well made with quality materials, therefore, it has to all be thrown out because of placebo. This thread makes me happy. |
I rated the Nite cables which are many steps above the Power 3, their intro cable. If you'd like to put $1500 down on a Nite cable and pull it apart, more power to ya. But, since I've held the thing (several of them) in my hand and you haven't, I can tell you, the 7 rating is accurate. And, no, I didn't tear apart and open any of the other cables either (yet I also rated those), but again, I invite you to use your own funds and try it yourself.
VD used to say the Power 3 was stranded wire and not solid-core single conductor. You can tell this by the way the 3 bends and flexes back, where the solid core conductor cables up the line hold their shape like wire clothes hangers do when bent. Their new site seems to indicate the Power 3 has "Lini Pure" conductors, maybe this is a mis-communication between design and marketing, I don't know.
Defend them to the end... Its a cheap-*** piece of housing wiring put in a garden hose to make it appear thicker |
The hose is to house the one piece of special sauce the Power 3 has, which is the dampening material (i.e. "Dynamic Filtering"). If you held one in your hands, it would be obvuious it was housed in a rubber "hose"/sheath, so it shouldn't be a shocking revelating to see it when you open it up.
It's their bottom-of-the-line cable, and lacks all the bells and whistles of the better stuff. At that cheap price, you get their basic cable with Dynamic Filtering which does make a nice difference as many many people have reported here and elsewhere.
Again, the irony of ironies is that the folks who feign shock and awe are the same ones who claim that power cables make no difference anyway.
Yet they complain that there aren't diamonds and rubies inside to justify the cost, when absolutely nothing inside would justify the cost in their eyes.
Speaking of diamonds, how much do you think it costs to "make" a 1 karat diamond? Pick it up off the ground, cut it and mount it and sell it for $100K. Why do these sorts of discussions always have to end up in re-educating people about capitalism. We always seem to have a lot of socialists/communists on these boards.
There's this concept called *value*. Value is totally independent of the *cost* to make something (see diamond example). If it performs at a level commensurate or better than other competing products at its price point (as the VD cords do), then it is good value for the dollar, regardless of what it costs to make.
That's how we decide to make decisisons in the marketplace, we spend our money based on value of the performance of the product, not its cost of manufacture (which is almost always unknown to us).
You also always have to re-educate people that there is more to the cost of any product than the cost of materials (which will almost always be your smallest and least important cost in bringing anything to market).
And, horror of horrors, in a capitalist system, you will be shocked to learn there's an actual *discrepancy* between what you pay for something and what it cost to bring to market. Yikes!
