Any issues known for the Pegasus?
Which fuses can you recommand?
Really. My friend with higher education in electronics, they don't believe in such tricks was wondered, that it's working. I especially called him for this experiment. I use Synergistic Research PurpleIt really does make a big difference
Didn't test. I read the reviews and got what I thought is better. That was the right right choice for meWhat are these differences soundwise?
Synergistic Research Purple is what I use.Any issues known for the Pegasus?
Nobody said there was a problem.Fuse problem? Get a DAC without fuse. Apparently some brands ?require? 'audiophile' some other do not.
No, it's perfect, but but this way is better )Fuse problem?
Disagreed - without fuse sounds better.No, it's perfect, but but this way is better )
Have you solution for Dell equipment made for Zimbabwe marker )BTW, it is a plug for the original IBM equipment, made in UK for South African market
Honestly, I did not believe in the magic of fuses either until I heard it for myself. In my analytical mind, volts and amps are just volts and amps, and a tiny fuse should be irrelevant. But it's not.
Stay updated on iFi audio at their sponsor profile on Head-Fi.
Never have been in Zim. However many years ago someone from Zim attempted to buy from me advanced Ethernet switches, don't know why from me and how they found me, I only had a consulting business, not a wholesale.Have you solution for Dell equipment made for Zimbabwe marker )
...or other companys DACs?By the way moving a fuse outside is a brilliant idea. Why no one follows?
Not better business to sell expensive fuses?
