DMSB
Member of the Trade: MSB
- Jan 7, 2016
Full disclosure: I am a employee of MSB
I just wanted to comment about the ability of various current MSB DACs to drive headphones directly.
Analog DAC, Platinum IV, Platinum V, Select DAC 1
All these DACs have a low enough impedance and sufficient power to drive many headphones but I do not recommend it. The reason is that a highly reactive load or a load with too low of an impedance at any frequency may cause the output buffers to overheat. Even if the load does not dammage the DAC a low impedance like a headphone will cause increased distortion and will probably not sound as good as an amplifier specifically designed for such loads.
Select DAC II:
There is no output buffer, amplifier or active circuitry. Any type of load may be driven from 0 Ohms to Infinity. Highly reactive loads are perfectly acceptable. The only thing watch out for is that the load does not feed any external power back into the inputs. Different loads do not cause any increase in distortion and do not change the power disipated by the DAC. All volume levels provide exactly the same impedance. The analog input has a high power buffer amplifier that is able to drive the same loads as the DAC.
As far as if the Select DAC II will work well driving any particular headphones here are the key factors.
1. The 75 Ohm output impedance must not cause too much coloration. This means that the headphone should either have a flat impedance, a high impedance, or an impedance that equalizes the audio in the desired way when driven by 75 Ohms. I have experimented with simple passive zobels to flaten the impedance of a few headphones that had wild impedances with good results.
2. The headphone must be efficient enough to reach your desired output volume with the power avalable. If your listening volume is 100 or less with normal level recordings and you do not need to go over 106 with quiet recordings then you have sufficient efficiency.
3.The headphones must be connected in fully balanced mode. Using 1/2 of the balanced output to drive a single ended low impedance load will result in significant crosstalk between the channels and may trigger the DAC to display an Error. It will not harm the DAC however.
I think it is cool to drive headphones directly with the Select DAC II outputs. It is the only electrical audio signal chain I know of that has zero active circuitry, zero amplification.
I hope this information helps
Select DAC II:
