husafreak
- Jan 6, 2016
Thanks guys, the silver cable looks interesting.
Silver coated Pure silver would likely be more expensive.Thanks guys, the silver cable looks interesting.
If you want a brighter voicing you can always remove the ear pads and pull out one or both damping materials under the pad. It’s a reversible mod as long as you don’t damage the pads.
Here i removed the black damper, but not the foam.I'm super interested in this! Can anyone who has tried doing that give impressions? If it ends up having the effect I think it would, this could be what pushes me into buying an ether flow.
I'm curious what the theory is for a coating of a metal improving the sound? So does the sound get filtered by the silver content? I have to admit it sounds dubious. So some of the signal is going through copper, and some through the silver coating? I'm only quoting you as I thought perhaps you might have thoughts about this as you mentioned it so you may have researched this a little.Silver coated Pure silver would likely be more expensive.
I'm definitely not an expert, so everything I say could be quite wrong. But I'm curious about the subject and have played with a few different cables.I'm curious what the theory is for a coating of a metal improving the sound? So does the sound get filtered by the silver content? I have to admit it sounds dubious. So some of the signal is going through copper, and some through the silver coating? I'm only quoting you as I thought perhaps you might have thoughts about this as you mentioned it so you may have researched this a little.
My Lavricables Grand 20 Core Silver cable has 20 conductors with 28 AWG each, equivalent to four conductors with 21 AWG each (according to https://www.wirebarn.com/combined-wire-gauge-calculator_ep_42.html).
No. Instruments sound a bit more realistic to me and there's a bit more clarity, but the jump in sound quality is not nearly as big as the jump in price. Even though the Lavricables is a steal compared to the Kimber Axios Ag at $4,500.Interesting post. To me, what you says kinda clears up some of my thought on cables and size and other properties added to it.
In your opinion, are these Lavricables Grand silver cables are a big jump from the DUM cables?
TSAVJason
Stay updated on The Source AV at their sponsor profile on Head-Fi.
If you call 2m very long.$4500? That would be a very long Axios Ag.
(Source)
Are you thinking of the Cu version (copper) for $830 or the hybrid for $2790?
(Source)
TSAVJason
Bummer. Here I was hoping you could give me a better deal.Yup long week! I was thinking copper
Advantage of silver is corrosion resistance, at least with some dielectrics, can't see it helping with litz wire. Skin effect at audio frequencies is next to non-existent.I'm curious what the theory is for a coating of a metal improving the sound? So does the sound get filtered by the silver content? I have to admit it sounds dubious. So some of the signal is going through copper, and some through the silver coating? I'm only quoting you as I thought perhaps you might have thoughts about this as you mentioned it so you may have researched this a little.
Check out Norne cable. I have Norne Solvine and it open up the soundstage over the DUM cable. Also it eliminates the low level microphonic of the DUM cable. If you like copper, look up Norne draug 3.If you call 2m very long.
(Source)
