Bastianpp
- Aug 11, 2016
My pair of ether too , but it get only the 100 hrs it that.These were playing music all through CanJam London, Indulgence show and at dealers... so they were 100% fully run in.
Thanks. I meant the two sliding "stops" that prevent the headband from sliding up the wire. Two little hex screws on each side. I want to adjust this down so the headband doesn't raise higher thus lowering the cups. I have some hex key sets but the smallest in these are too big.
I own the C Flow but did a long test A/B with the Z1R before buying.Anyone here who transitioned from Ether C Flow to Sony Z1R and could share their experience if they are happy or regret their decision!
Thanks for your feedback.I own the C Flow but did a long test A/B with the Z1R before buying.
The Ether have a much more balanced tonality with no emphasis on any frequency while the Z1R is definitely too dark to my ears.
The bass of the Sony felt way too exaggerated and sounded muddy, not very defined.
With the C Flow you give up a little bit of quantity in the bass but you gain much more in quality.
My 0.02.
You need the 0.050" hex tool, which is the smallest sold at the hardware store I visited. You can then back-out the two hex bolts by a few turns on each stop, move the stop, and retighten. They take a death-grip on the memory wires and absolutely will not budge once tightened! (Turn slowly, the bolts are put in with red Loctite and you may snap the thin hex tool if you aren't careful. I found no need to replace the Loctite.) This solved my years-long problems with the headbands constantly sliding upward on multiple pairs of ETHERs.. you can never tighten the big Philips screw enough to prevent that, and by trying you can easily strip the (inexplicably) plastic screwhole.
I attempted something like this, but the tiny hex head screw driver couldn’t back out the screws without bending, so I left it alone. If there were a way to more easily adjust the permanent bars, I’d be all for it, as I have a little too much slippage for my taste on the sliders and have already ruined a set at launch by overtightening the screw. The vinyl female end can be easily stripped!
Interesting that you mention this.Can any owner of the C flow share eq setting? After spending sometime with bass heavy phones like aeon open flow and focal clear, I am seeking to increase bass response on my C flow, which I never felt needed before.
I own both the C Flow and Clear and I find the bass on the MrSpeakers muddy and imprecise compared to the Clear.
I’m not EQing but if I’d ever do that I would probably reduce a bit of bass on the C Flow rather than adding.
Another possibility is that what I’m hearing wrong on the C Flow is not the tonality or bass quantity but simply the effect of these being closed back headphones with the unavoidable sound reflections within the cup.
If you’re not happy with the quantity of bass on the C Flow and you want a closed back try the Sony Z1R.Interesting. I hear exactly the opposite. That maybe because difference in the setup. I drive them only from Hugo. To my ears, bass in the C flow is cleaner and more transparent, but it lacks quantity. I say this after hearing ether c flow, clear, and aeon open flow. When I use the later two of them with bass heavy music, I found they deliver similar bass quantity, while the c flow lacks quantity.
