Capt369
- Feb 28, 2007
Does anybody also have the fad hope vi and make a comparison?
I have an HA-2. I can't say one way or the other if you think it will be good enough of an amp for the Primes, but they drive my Primes fine. Listening pretty loud out of an ipod touch 6gen with the HA-2 dial at 4.
I've never been a participant in Amp discussions because I don't typically hold the same opinion as most here. For me, if I can't max out the Amp due to volume being too loud, then the Amp drives the headphones fine. The HA-2 does that....to my ears. Take that with a grain of salt.
I also have an old Headamp Desktop Amp/Dac, and those drive the Primes fine also. When I read comments regarding 500 dollar amps not being enough to drive headphones it boggles my mind. As long as you aren't maxxing the amp out, or it feels like it is stressed, and there is power to spare behind the phones...I say they do the job.
Varying sound signatures and good pairings are a whole 'nother topic, but as far as capability goes....yea.
It needs to be pointed out that sufficient volume =/= sufficient power.
My Aune T1 drives my Omnis to sufficient volume, but it does not provide enough power. This difference is rather obvious when a/b'ing against my Mjonir. It's also obvious when comparing power hungry planars like the Alpha Prime and LCD line on diffent amps of varying power output--these headphones need more power to sound their best.
Those of you who claim that the Alpha Prime sounds fine on weaker amps--have you ever heard it on an amp putting out 3 watts or more? Your advice is less helpful if you have never had an opportunity to hear the difference.
If you have heard the difference and think it is negligible then that is fine. Some specific comparisons would be helpful though if you are going to dismiss what I think is clearly the best advice (that is, to get an amp that provides quite a bit of power).
I am not saying more power will not help. Yes, I agree the driver is better controlled (especially in the bass) with more power. I am saying ime the benefits are very subtle compared to what is suggested on headfi. To say that the Alpha Prime should have 3W of power to sound its best is just ridiculous considering the amount of return that is found for the average user. To my ears the Cayin C5 (700mW I think) sound nearly as good as much more powerful amps that I have heard.
I am speaking to/for people that would never consider this wonderful headphone as they feel (by comments like yours) that they would need a expensive amp to enjoy it. I am absolutely sure that someone that owns an HA-2 and buys the Prime before it is sold out will highly enjoy it to their full extent. If you wish to spend more money for a much greater perceived difference please don't discourage people from thinking they can fully appreciate it with less power.
Well, to clarify my earlier point, I would still encourage people on a tight budget to get the Alpha Prime while they can and to invest in whatever decent dac/amp they can afford and just put "more powerful amp" on their to-buy list for another time.
My main point is that a powerful amp is not excessive by any stretch.
Has anyone used an asgard 2 with the primes?
Click the "Search this thread" button and search "Asgard". You will find numerous responses about how well it handles the Alpha Prime. The consensus appears to be that the AP does indeed sound great with the Asgard 2.
I enjoy Mojo -> Asgard 2 -> APs alot!, even more than just using the Mojo to drive the APs.
