The first serious headphones I got – unless you count both variations of firstgen the MOMENTUM – were MrSpeakers’ Mad Dogs (MDs). This was after the Alpha Dogs (ADs) had been introduced. Certainly there were times in the lead up to my buying the MDs when I considered going whole hog, as it were, getting the ADs instead of the MDs. I was more reasonable back then; now, I package an item together with its first upgrade. If I’m reasonably confident I’ll like the standard, that’s reason to be confident, all things considered, I’ll like the deluxe. So I pick the latter and that saves me money in the long run. Or so I tell myself.
The MDs are a great headphone, especially for the price. My experience is limited, of course, but I think they’re about the best you can do for 299USD. And the fact that Dan offers an upgrade path including the ADs is all the more reason to consider the MDs. For the time being, upgrades to the flagship Alpha Primes are on hold until Dan figures out the right way to do them. I’m certainly signing up for an upgrade once they’re available. If it turns out that uprgrades in this case simply aren’t feasible, I may very well buy the Prime outright. I’m that confident in what Dan is doing.*
But I want to say something about the AD + H10 pairing. Sharing some of my general thoughts on the AD should indicate what I think the H10 is capable of. Someone earlier on this thread said that a new flagship headamp from Gustard is in the offing. If that’s the case, then I may very well make the upgrade. I’m that confident in what Gustard is doing.
It’s by now obvious that the H10 is a little ridiculous with planars. I haven’t heard another headamp with such a vicegrip on this sort of driver. One of the things I’ve always loved about planars is that, in contrast to many of the dynamic models I’ve heard, the headphone’s SPL can often outstrip its volume setting. In this way, you can get plenty of slam without pushing the volume to the point at which distortion becomes noticeable. Usually to achieve a similar effect with dynamic drivers one turns to closed cups, which – according to the lore – tends to compromise overall sound quality.
The ADs sound like what you’d get by putting a planar driver in a cup that’s supposed to mimic the strengths of planar drivers. Imagine a planar headphone perfectly mimicking a planar headphone. I don’t mean that negatively. Two of the oft vaunted strengths of planar drives are bass and female vocals. I want to appeal to a particular album as showing that the Alpha Dog + H10 pairing excels in these areas – Data Romance’s Others. Auditory Canvas’ “Solace of Remembrance”, a test track taken from their Earth by MrSpeakers&Co. over on the ADs’ thread, is exemplary. The track, featuring Shawni, efficiently showcases the ADs’ virtues.
Take, for example, timbre – something for which I admire the HE-500 + H10 pairing. To a certain extent, I think of the ADs as a closed back HE-500, i.e. an HE-500 with more slam and isolation. Tonality is also perceptibly similar, with each having a dip in the mid bass and some sparkle in the treble. This makes the ADs well suited for dubstep, given their, so to speak, “dogmatically vigilant” mids. What can often become glare and/or etch in the upper mids with the T50RP driver is absent here. Instead you get an incredible sense of presence because of an emphasis in the upper mids renders the timbre of female vocals so realistically. Voicing is perhaps the central ingredient in a headphone’s timbre. Because the ADs’ voicing is top notch, the overall perceived timbre excels.
If an amp is transparent, then it’s supposed to give you your headphones as they are. If they’re colored, the sound will be colored; if they’re neutral, the sound will be neutral. The H10 is transparent. If your headphone sounds great, the H10 doesn’t get in the way of the greatness. In fact, it makes them sound all the greater. And that means, in this case, that the H10 is itself a great piece of kit. Conder the O2. While it’s adept at getting out of the way of your headphones, there’s only so much you can wring from e.g. the HE-500 with the O2. The HE-500s are exceptional headphones, but they sound better with the H10 than they do with the O2.
It’s difficult to present all at once and accurately what you think are an amps strengths. So I’m happy to answer specific questions about this pairing. As a DAC, I paired the HRT microStreamer exclusively with the H10. My current second-string chain is an E18 feeding a Cayin C5. Either way, the source material is primarily Tidal and sometimes Spotify.
* In point of fact, I didn’t upgrade from the MDs to the ADs but bought the latter outright. I no longer own the MDs. They were sold before purchasing the ADs.
