- Jul 17, 2013
Are there any aftermarket cables for the Alpha Dog with portability in mind. Cables with reduced weight, size, thickness and terminate in a 3.5mm jack.
Review unit's not the only thing with a screw loose (rimshot).
Am I the only one who thinks that screw-gate is a cover for a running change in the tuning of production units that is a result of the tepid reaction to units delivered in the first 6 weeks?
Including THD, right. Are you trying to undermine your own criticism?
My whole point was that the T50RP driver is inexpensive, small, and just has more limitations than more expensive, more technically competent drivers that you're more likely to see in good headphones costing $1K+.
Yes. You can search Q Silk cable which is just reviewed by WNBC last week, the other after market cable brand you can check is Moon-Audio or http://btg-audio.com but to tell you one thing the prices are not cheap.
Sigh...
This was exactly what I feared with the Alpha Dogs. Obscure connector, garden hose cabling and the only options being expensive cabling from others. Perhaps I'd call myself a conspiracy theorist but it's almost as if this was a gesture from MrSpeakers to DIY cable makers and frankly a gesture I don't appreciate for portable use on a $600 headphone. I'll guess I'll have to see if I can make my own cable.
Make every day a fun day filled with music and friendship!
Stay updated on Dan Clark Audio at their sponsor profile on Head-Fi.
I'm definitely not speaking for Dan here, but I think the current cable is made with the idea that the Alpha Dog will be used in homes and studios rather than for portable use. A portable style cable while desirable for some is probably an expensive option for relatively small batch production. How many shorter and lighter portable cables will be preferred over longer and heavier cable? I'll pick heavy and long over short for home use. As for the connector, it is easy to attach and detach. Can be purchased for less than $20 and a hassle if you have to import them outside of the US. But, no conspiracy. An industry standard would be nice but not going to happen.
Hi... We've had a lot of request for a 3.5mm cable.
One consideration we have is to use the current cable, with a 3' tail and an 18" Y split. The cable would be the same but shorter. Doing a lighter and thinner cable is possible. Either way we'd sell this is an optional add-on.
Using a thinner cable will take more time. For those who have the phones would you consider the current cable a good solution? Your feedback will help our design best meet your needs.
For home sound there are many better headphones out there. It's the closed, portable space that is severely lacking good, neutral headphones with decent/large soundstages.
Thank you for speaking for every use case.
I work from home, and I have three pairs of headphones (I will when the AD's arrive).
M50's - portable use
Sony A900's - For all day home use when I am alone
Alpha Dogs - For when my wife is either in the same room, or when she is watching TV on the other room, and I want the isolation at home.
Tell me, for the third option, what's the better choice?
