MrSpeakers Alpha Dog Revealed! - The World's First Production 3D-Printed Headphones
Dec 12, 2013 at 9:16 PM Post #4,456 of 9,071
Oregonian
Oregon
I was  reading the tour comments and I noted a well written comment from one reviewer saying he didn't find the listen enjoyable. I thought something must be up, so I blew the  whistle to call the Dog home.
I left a screw out on the baffle assembly.  I built all the first units, so I own it.  The screw wasn't loose under the pad so this was my error in assembly.  The effect of that screw missing is to non-linearize and reduce the bass and harden the sound.  The hole was likely covered well by the pad but as the pad compressed from multiple shipping and uses (as should be expected) it probably allowed the hole to be exposed.
I've fixed it up and will send it to the next reviewer, MLE.  If any of the earlier reviewers want to hear it again it's worth it.
Count me in. It left here to go to Seattle so might have been degrading. Either way I'd like to make sure what I heard was real before I buy one, so please put me back on the list.
Dec 13, 2013 at 7:41 AM Post #4,458 of 9,071
hans030390
I would be willing to re-evaluate the AD.
Dec 13, 2013 at 10:51 AM Post #4,459 of 9,071
eac3
Just to make sure I understand. There is supposed to be a screw present. When present, it is supposed to be loose. The Alpha Dogs on tour did not have said screw in the first place.
Dec 13, 2013 at 12:42 PM Post #4,460 of 9,071
San Diego, CA
No, this is an assembly screw on the baffle.  There are 20 screws in each headphone,14 get taken out repeatedly to tune each phone (tuning can require 0-10 iterations).  We did a simple process change back in October to fix this, we build and tune one phone at a time and have trays for the screws so we never have one left.  Old mechanic's trick.
Dan Clark Audio Make every day a fun day filled with music and friendship! Stay updated on Dan Clark Audio at their sponsor profile on Head-Fi.
@funCANS MrSpeakers https://danclarkaudio.com info@danclarkaudio.com
Dec 13, 2013 at 1:14 PM Post #4,463 of 9,071
San Diego, CA
Correct, this is not a user service screw or anything.  The reason it affects the sound is that it exposes the inside of the cup to the ear-side of the baffle with a pinhole, that affects the sound.
Dec 13, 2013 at 4:09 PM Post #4,464 of 9,071
koolas
I played with screw a bit, and I think I ended up with half-turn brighter signature than the default setting. Must say I love it this way. I was wondering what would happen if I opened port even more, but it says on the tool not to abuse it, so I'm leaving it as is. Sound is great, definitely worth $600 :)
There is one thing in particular that blew me away, and it is binaural sound. I just got one of those binaural records by Dr. Chesky's, and listening to it right now. It feels epic, essentially epic :D
Dec 13, 2013 at 4:33 PM Post #4,467 of 9,071
kstuart
  Does anyone know adjusting the bass on the Alpha Dogs how effect the mids and highs?
Since headphones are right over your ears, increasing the bass on headphones will lower the mids and highs.
Dec 13, 2013 at 4:40 PM Post #4,468 of 9,071
kstuart
Remember that when you are sitting in a room listening to speakers, you can feel the bass as well as hear it with your ears.
So, when we use headphones, if we connect the exact same "flat" sound that we heard on the speakers, it will sound like there is less bass.
In other words, if you have headphones with perfect flat frequency response, they will sound a little "bass light" to most people.
Thus many headphones increase the bass to try to make it sound comparable to using speakers.  In the process, this lowers the level of everything else (mids and highs).   This is why headphones that are considered to be "detailed" are ones that do not increase the bass in this way.
Dec 13, 2013 at 5:21 PM Post #4,469 of 9,071
pdrm360
I wanted to know adjusting the bass on the AD could change the flat frequency response of the mids and highs parts.
Dec 13, 2013 at 5:59 PM Post #4,470 of 9,071
kstuart
In theory, it ought not to change the response of the frequencies above the bass, except (as I mentioned) relative to the bass (i.e. the whole mid-and-treble will be down as a whole, relative to the bass).
However, you are changing things inside a closed acoustic space, so it is possible that there could be unanticipated effects.
This is where MrSpeakers might be able to shed some light, of course.
