14christ
Absolutely excellent. Great extension, texture is fantastic and overall clarity is superb. The note weight is serious.Looks sweet! How is the transient response?
Yeah, but the tires, how are the tires?Absolutely excellent. Great extension, texture is fantastic and overall clarity is superb. The note weight is serious.
That's exactly why I bought the vehicle...the tires of course!Yeah, but the tires, how are the tires?
They'll run flat aren't they?Yeah, but the tires, how are the tires?
Stay updated on Moondrop at their sponsor profile on Head-Fi.
Very much a run flat signature.They'll run flat aren't they?
Hi,
Just did the filter mod on my Aria and I'm having mixed feelings.
Is there anyone that didn't liked the result at all or is it common sense that this mod it's an improvement?
I'm perceiving a dip in the mids that bring up the bass just a little at the cost of loosing the punch and frontality in some instruments. That rim's beat in Your Latest Trick from Dire Straits is a example. It's much less evident.
Am I correct in affirm that the only thing this mod does is bring down the mids to make it more neutral sound?
Thanks.
It's more like the mod brings down the quantity of the bass while increasing the quality .
That's why you hear "loosing the punch" as the bass is reduced in level & rumble. The "quality" increase is the increase in bass resolution aka making bass faster. It also affects why you feel mid lose its "frontality".
So basically, removing the metal hex filter alters the sound a lot. Your choice, your preference .
For me, I remove the hex filter to clean it up then reinstall it. In stock form, the hex is partially blocked by excessive adhesive .
Not necessarily that you did it wrong. Some people just remove it altogether, running only on the cloth filter .Ohh I think I did it wrong then. I didn't reinstalled it. I will remove the adhesive and put it back for further evaluation. Thanks.
I am using Shanling M8 and Spiral Dot tips. I think the M8 has enough definition for the Variations.
I think in general the Variations has good bass speed but somehow it sounds congested to my ears for a range of frequencies. I should have tried the CP155 but I haven't bought it yet.
I am comparing it with NM2+ and NA2+ and KZ AST.
I like to test my IEMs with these two albums for low end control.
https://www.amazon.com/Bruch-Scottish-Fantasy-Violin-Concerto/dp/B07CPBVVWN
https://www.highresaudio.com/en/alb...r-daniel-harding-brahms-ein-deutsches-requiem
And, it definitely doesn't sound good enough. Brahms: Ein deutsches Requiem I think this album is quite challenging for IEMs. The supporting orchestra sounds good however when the whole choir sings together clipping can result quite often. Also, the pinna gain frequencies aren't really my preference which can lead to unfavorable tonality on instruments such as saxophones sounding wrong and orchestral strings sounding flat. And Joshua Bell's Scottish Fantasy mostly sounds good with the Variations but the lower string notes sound quite muddy due to the overly boosted bass.
Maybe you are right about the M8 having dense mid bass. I will definitely try more tips but it is hard to get tips for 6.5mm dia. nozzles and the stock tips kind of suck. Do you have any recommendation?I was curious what you are hearing and listened to the Bruch record on Tidal.
I cannot find any issues with the Variations' technicalities. Tuning is another matter, the Variations have a distinct character and sometimes it works in favor of some music, sometimes against it. But I didn't hear the issues you are describing.
It seems as if the Variations simply has a tuning which goes against your preferences. It's a valuable opinion with all the positive feedback the Variations is getting, and a good reminder that what works well for others may not work well for everyone.
Maybe the Variations are not for you. If you have a chance, listen to the Sony IER-M9, you might like that, or the Dunu Luna which has a similar tuning to the NM2+ and has unreal speed and dynamics. Very exciting IEM for classical music.
PS: I also read headfonic's review of the Shanling M8, and they point our a strong, dense mid bass.
Maybe that exacerbates the issue you are having with the Variations too.
hey hey.. we meet again. glad to see you are enjoying variations as well. it's currently my fave iemI was curious what you are hearing and listened to the Bruch record on Tidal.
I have a pretty big tip collection and on the Variations the Spiral Dot ++ give the best results for my ears and preferences.Maybe you are right about the M8 having dense mid bass. I will definitely try more tips but it is hard to get tips for 6.5mm dia. nozzles and the stock tips kind of suck. Do you have any recommendation?
I think the Variations is good, but the more I listen to it I find myself preferring Single DD goodness and the pinna gain of it really doesn't work for me probably due to my narrow ear canal.
The NM2+ and NA2+ IMO are so underrated as they can sound quite bad with wrong tips and cables (well, if you are a believer). Especially if you can get the NM2+ to sound right, that treble is unbelievable. Yea I will try the Sony and both the Sony and the Dunu are over my budget sadly.
