H T T
- May 11, 2013
Guys, I think my right side of Aria is dying.
From the beginning of the week to now, the volume on the right side just got lower.
I contacted the AliExpress store and they asked me to change the filter. I changed it, but it didn't solve the problem (I already imagined that wasn't it).
I recorded this video and sent it to them:
https://photos.app.goo.gl/NJuzCeZkERVdmpWGA
They said that the problem was not very clear. Can you hear? For me it's very audible that the right side is MUCH lower, I hardly feel the bass on the right side, it's practically muted.
I was unlucky. The point is that sometimes it works well, sometimes it gets low. The store offered me a possibility of a partial chargeback, but that doesn't make sense to me, what am I going to do with just one functional side of an IEM? And I don't know if the problem is bad contact on the cable, or some internal component on the right side. @MOONDROP , help me, please.
Check the filter for clogging. Then try replacing the filter even if the filter is not clogged with earwax.
I am quite biased against fabric-covered cables, so take this with several pounds of salt, trying a different cable may make you much happier with the Aria.
