chickenmoon
Thanks for impressions between two of them. Tansio Mirai also bugged me the other time before decided to buy KPE.
You said sub bass is better on KPE and wider sound stage, its a plus for me. The only statement you made me worried is mids on KPE a bit dry compared to TSMR3. But from many reviews and impressions i read, i already imagine this iem is towards to bright, not warm
IMHO KPE is very track/recording/mix dependent , if the mix is thin, it'll sound thin. I think voices/mids are pretty much where they are in the mix too, if they are distant in the mix, they'll sound distant, if they are forward in the mix, they'll sound forward. I feel there is little emphasis anywhere in the spectrum apart from sub-bass. I regard them as quite unforgiving and sometimes I wish they had a bit more warmth, other times they had a bit more energy in the upper mids/presence region but on the plus side, as there is no bleed into the mids from either side they generally have pristinely clear and detailed mids as no other earphones I've got. Also due to its sub-bass boost, sometimes sub-bass may bleed into mid-bass and overshadows it a bit.
