Wow, N E A Tdone mate
Moondrop in-ear monitors Impressions Thread
- Thread starter FastAndClean
DynamicEars
- Jan 5, 2019
Wow, N E A T
we talked about that actually, just make a spacer mod. Cut your spare eartips neck, just few mm and put in before your spiral dots, to hold your spiral dots go deeper.
docentore
- Feb 27, 2013
I haven't tried this on KPE but on DM6 it still made my spiral dots falling off. Some were left inside ear canal and I lost one or two.
Twine just works perfectly for me but YMMV
well that's actually easier. I can cut some of my old tips.we talked about that actually, just make a spacer mod. Cut your spare eartips neck, just few mm and put in before your spiral dots, to hold your spiral dots go deeper.
Fxxk, i just got the true sound of kanas pro. Downloaded USB Audio Player Pro, got my Tidal MQA works!, Got my es100 together with s10plus...
Damn boi ... Ive been listening to compressed crap before this ....
SilverEars
- Sep 18, 2013
USB audio player pro has bit-perfect mode. Look for that in settings.Fxxk, i just got the true sound of kanas pro. Downloaded USB Audio Player Pro, got my Tidal MQA works!, Got my es100 together with s10plus...
Damn boi ... Ive been listening to compressed **** before this ....
Edit: never mind if you are using bluetooth.
since you taking up bit perfect here. Can i know if es100 can do usb dac connection?USB audio player pro has bit-perfect mode. Look for that in settings.
SilverEars
- Sep 18, 2013
I don't see why not if it works as a usb DAC. I recommend you try the ES100 connected via usb with Tidal on your computer. Go to Tidal setting, and set the DAC for bit-perfect mode.Can i know if es100 can do usb dac connection?
So you lost one or two tips inside your ear canal? LOL, I know that isn't what you meant but that's how I read it
Oh se es100 support usb dac? Damn!!!!! I'll try now. Im doing a critical comparison between es100 and xdsd with USB Audio Player Pro now.I don't see why not if it works as a usb DAC. I recommend you try the ES100 connected via usb with Tidal on your computer. Go to Tidal setting, and set the DAC for bit-perfect mode.
For now. Bluetooth SQ, hands down es100 outperform ifi bluetooth. But with usb, ifi is having crazy soundstage.
I will try usb with es100 and i will update.
Treble is 1-2 db higher too like i rememberive read a simple review in one of the shopping sites. Maybe Aliexpress if im not mistaken. The signature is the same. They said that the new KXXS has a better packaging. Refined bass and a tad better mids. I guess if you already own kanas pro, it does not worth the upgrade. But for a new buyer, that's definitely a better buy.
Wheel Hoss
Can anyone confirm this?
Does anyone here interested on having comparison ifi xdsd vs es100? bluetooth and usb dac.
I have everything covered. Let me know if i should write a short review here.
LaughMoreDaily
Can I ask a "dumb" question? On the Crescent does the line with the word Crescent above it on the earphone mean it goes in the left ear?
If wearing the cable over the ear does it matter how the earphone is placed?
Thanks.
Thanks.
where can i find short balance 2.5mm 2 pin cable? i want to connect it with es100 and make it as an ultimate bluetooth earphone.
Total: 43 (members: 8, guests: 35)
