redrol
https://www.amazon.com/Moondrop-kanas-Dynamic-Earphone-Silver/dp/B01K6JQFVC
In stock on the 6th of next month. Still a wait.
Reporting back on the Crescent.
After dry
Where did you find the information that the Aria uses the same driver as the Crescent?
I like the frequency response of the Crescent, unoffensive, but the transparency and resolution are low and I found bass to be light below 200Hz
EDIT: I have to correct my statements.
After comparing the Crescent to the MH755 and my modded JVC HA-FD02 I am impressed by the Crescent. Frequency response is very balanced and natural, and actually the transparency and detail is not that far from the JVC. Even the soundstage is good.
MH755 has a bit more bass (elevated) but mids are much more natural on the Crescent, and the bass quality of the Crescent is also much better, better texture and detail. Overall I am impressed what is possible for $30 and am happy I bought it. Maybe I’ll get more for family and friends.
After dry
Crescent:
https://m.blog.naver.com/PostView.n...7146456&referrerCode=0&searchKeyword=Crescent
Aria:
https://m.blog.naver.com/PostView.n...21335908106&referrerCode=0&searchKeyword=Aria
(Use Google tradutor Korean to English)
damn based on that (and the graph) im starting to leaning more towards aria.
im not confident enough in doing that since im afraid that both ears won't have the same FR anymore if i did that mod. the only thing im quite confident at is doing mmcx mod hahaha (and prolly the only mod im will do)I think Crescent vs Aria difference is just in the size of the front vent. You could probably achieve a similar response by opening Crescent and reducing the rear volume like yuriv did (that is if you're into DIY)
please measure them without the foamI just received one of those clone IEC 711 compliant earphone couplers and tried it out on my Moondrop Kanas Pro with ear bud foam mod... looks great!
thanks anyway, very nice raw graph, they are a tad calm and smooth for me lately (i think i am becoming a treble head, i am not sure yet) but still very goodI actually do not have the stock grill anymore. I bought generic ones on Ali Express and used those since I lost one of my grills. So any measurements wouldn't be super accurate. The foam just softens the upper treble spike.
Very cool . What is the earbud foam mod?
