Armaegis
Modern Modder Man of Manitoba
HTML... uphill, both ways!
- Oct 18, 2009
Before you guys go dropping mucho moolah on power conditioners, determine what (if any) the power issue is, if you *really* need that type of device in your chain, or if it would be better to try and track down to eliminate/minimize the issue in the first place.
I've had good luck with Furman units. Granted I have one of the fairly large beefy units, but I also have the small AC215a which worked wonderfully at reducing audible hash in the power lines.
If you don't have any real issues with power, then just get yourself a really nice surge protector and call it a day. Brickwall has already been mentioned. Zerosurge is another one. SurgeX is probably the easiest one to find on the market.
If you have a lot of power sags (like brownouts) or overvoltage happening, then a voltage regulator like one of the Furman AR family will do you better.
