Monoprice Monolith M1060 and M560 Planar Headphones
post-14598822
Post #7,411 of 8,007
jotaku
Denver, CO
Denver, CO
are you okay with mojo?
You should be fine with just about any good amp. The 1060s don't need a lot of power. I've run them just fine off my Oppo HA-2 on low gain.
post-14599410
Post #7,413 of 8,007
cirodts
I wanted the audize lcd2 but they are exaggeratedly expensive in Italy 1,200 euros used, c is who says that m 1060 are very good and better than lcd2 and who says they are not so good, but the price of m1060 is very good.
But the m1060 are good for thrash metal music?
post-14604603
Post #7,414 of 8,007
OldDude04
Over yonder
Over yonder
I managed to snag a brand new pair of Audeze vegan pads with glue rings at a steal of a price for my M1060s. Can't wait until they get here next week.
Reactions: Pahani
post-14616359
Post #7,415 of 8,007
OldDude04
Over yonder
Over yonder
I got my vegan pads in this morning, and they are a game changer for me. I feel silly for not getting a pair much sooner. They are ridiculously comfortable, like MrSpeakers Aeon Flow level comfortable. But the best part is not only did they not cost me low end like I thought they would (I've had velour pads just kill the low end in the past), but they increased the bass by a good bit. I'm in love. I'm running Grace SDAC -> Emotiva A-100 -> M1060 with the vegans and smiling like a fool. :L3000:
post-14616688
Post #7,416 of 8,007
theangelboy
Utah
Utah
Website
polygonbronson.com
Yeah the vegans are fantastic. I was going to return my m1060 before I got the vegans. In this day and age of both legitimate companies and cheap knockoff companies that make pads someone really, really needs to make an exact clone of the vegans. Both for Audeze and M1060 owners.
post-14621118
Post #7,417 of 8,007
atilllla
Hungary
Hungary
Where could you get one? Im currently using these. "110 mm angle sheep leather pads" from aliexpress. and they are quite good as well. With printed hexa grill and this type of fazor. https://www.thingiverse.com/thing:2666205
This one changes the sound dramatically. This fazor is special because it lets the air moving at the side of the fazor blades. This releases the sub bass. Because from the earpad side the membrane is not muffled anymore. You can experience it when you lift the headphones a little bit from your head.
I think this is why audeze vegan pads works well with m1060 s. It lets the air venting more than stock faux leather pads.
post-14621991
Post #7,420 of 8,007
theangelboy
Utah
Utah
Website
polygonbronson.com
Reactions: trellus
post-14622376
Post #7,421 of 8,007
jj69
post-14622383
Post #7,422 of 8,007
theangelboy
Utah
Utah
Website
polygonbronson.com
I have a pair on the way myself. I cannot remember who it was, but someone here was making hex backplates specifically for the m1060c. Anyone remember who, and if he's still offering them? I don't think the standard m1060 grills will fit.
The grilles are larger and have a different hole pattern. Consequently, they changed it so it's compatible with the Audeze grilles. Here is the Thingiverse file for the M1060C grille. https://www.thingiverse.com/thing:2820652
post-14622559
Post #7,423 of 8,007
jj69
post-14629344
Post #7,424 of 8,007
Jim85IROC
My 1060s arrived yesterday. I tried them briefly last night connected to my phone via a Dragonfly. Right away I was impressed at the clarity and the full bass response, but the Dragonfly didn't have enough headroom to do the job. Today I brought them to work and played them on my Monoprice DAC/amp. Again I was impressed with the great clarity, powerful bass, and unlike with the Dragonfly, with the power of the Monoprice amp, there were fantastic dynamics. When I switched back to my HD600s, it felt like I lost all of the details and dynamics, but the more I listened and compared, I started to feel like the "detail" I was hearing might be a harshness, perhaps from that 5k ringing. It seemed like they were getting fatiguing, where the HD600s, while lacking the midrange detail, were just way easier to listen to.
But, I might be jumping to conclusions. I had a headache all day, and was listening at fairly loud volumes, plus they're brand new. I left them on when I left work, so they can play all weekend to help break them in.
Lastly, I ordered a Schiit stack. :D The Monoprice DAC/amp has been fantastic with the HD600s, and has way more power than I need to drive the M1060s, but with a 10ohm output impedance, I don't think that it is doing anything to tame the ringing in the monoprice cans. The Schiit Vali has a much lower output impedance, so the damping factor will be much higher.
post-14629865
Post #7,425 of 8,007
atilllla
Hungary
Hungary
Thats the main task with this great cans: to eliminate the harshness. There are many ways to do it.
The easyest it to unscrew the grills and put a 5-6 cm diameter paper towel spot behind to it (to the center). The size of the paper towel is the key. If its too big then you loose the space of the music. If its too small then the harshness remains.
