Monoprice Monolith M1060 and M560 Planar Headphones
Discussion in 'Headphones (full-size)' started by wordfool, Sep 13, 2016.
484 485 486 487 488 489 490 491 492 493
495 496 497 498 499 500 501 502 503 504
  1. youngarthur
    Sorry to be off topic, but to take this to its logical conclusion,If you use two of the horns, that granny used for her hearing,(One for each ear), This gives a huge soundstage, heavy bass, forward mids, but a recessed treble. The main drawback, is the weight, which means you can only wear them for around 3 minutes, before the weight on top of you head, becomes unbearable. Hope this helps.
  2. Artyouth
    Sorry I don't know that horns. (maybe have to seach and have a try)
    This funny looking discs mainly works for reflection. It adds an intimate favour on the mid, improve imaging and clarity. N̶o̶t̶ ̶d̶o̶ ̶m̶u̶c̶h̶ ̶o̶n̶ ̶o̶t̶h̶e̶r̶s̶ ̶s̶o̶u̶n̶d̶ ̶n̶a̶t̶u̶r̶e̶ ̶s̶u̶c̶h̶ ̶a̶s̶ ̶s̶o̶u̶n̶d̶s̶t̶a̶g̶e̶/̶F̶R̶/̶d̶y̶n̶a̶m̶i̶c̶ ̶e̶t̶c̶ (Tested, it does). And it's weight less then 10gm.
  3. Frank88
    Links to the ear hooks are below. Clip size doesn't matter because you throw away the tiny clips that come with the ear hooks and replace with our clips or ones you make yourself.
    I do not have permission to post CAD files to thingiverse. I am still making clips for iSine and M300 owners here on headfi. PM me if interested.
    Amazon
    https://www.amazon.com/PL-Samsung-W...531025807&sr=8-72&keywords=bluetooth+ear+hook
    same on Aliexpress
    https://www.aliexpress.com/item/5mm...396.html?spm=a2g0s.9042311.0.0.27424c4dCGcqHJ
    And same again on ebay
    https://www.ebay.com/itm/lot-5-10Pa...var=441361100816&_trksid=p2060353.m1438.l2649
    Here's a thinner clear set as another option. These fit smaller ears a little better than the black ones.
    https://www.aliexpress.com/item/10m...1359-4a4c-a5e6-610d6677d5d7&priceBeautifyAB=0
  4. Frank88
    That's a great solution. Much easier than printing replacement plates. The new plates I made in the pics posted earlier took three hours to print each side, so six hours total on the 3-D printer, not including post-print clean-up or the design time. My stock cushions are still in new condition so couldn't bring myself to cutting them up.
  5. mingnormous
    Been lurking around for a bit. Decided to mod the m1060 v2. Got zmf suede pads coming in.
    I noticed people getting custom grills as well. I was wondering if that added anything to the the way the headset will sound? Planning to use the new ZMF pads and doing a fuzzor mod. Will adding a 3rd mod like a custom grill add anything to the headset?
  6. theangelboy
    A 3D printed grille is an essential mod in my opinion. It's pretty cheap and only does good things to the sound. Better Soundstage, a more even frequency response, and a more natural sound are the biggest benefits. It's easily reversible too. I also think the honeycomb grille looks better than the stock one by that's my personal preference. Just listen to the headphone with the grilles removed to give you an idea of how it will sound with 3D printed ones, getting rid of all of those nasty reflections from the stock grille.
  7. mingnormous
    Thanks for responding!
    Great! Where is the best place to get one made? I see there are files created by Vracer111. What materials should I use and what's the average price?
  8. theangelboy
    I paid a little under $10 (including shipping, which will vary) and I ordered them from @SomeTechNoob. It was printed with black PLA. However, I don't know if he is still printing them atm. I have also had other 3d parts printed at 3dhubs.com when you could order from private people. The local guy I used was quite reasonably priced. Depending on where you live, a local UPS store might be able to print them.
    jotaku and mingnormous like this.
  9. atilllla
    I have a black spare pair of grill. Vracer111 -s version. If you are interested I can send it to you. Its very good, the only problem that I dont like in it, is that it makes this big headphone even bigger and bulkier. I have made an own version, thich has slimmer edges. https://www.thingiverse.com/thing:3196741
    mingnormous likes this.
  10. mingnormous
    Just PM'd you.
  11. mingnormous
    I checked out 3dhubs, it quoted my close to $200 for aluminum. Am I doing something wrong? haha upload_2018-11-5_9-53-31.png
  12. SomeTechNoob
    Haha, use plastic(PLA or PETG). Aluminum 3D printing is very expensive, especially the machines.
  13. mingnormous
    Thanks!
    Much better!
  14. jotaku
    I also ordered from @SomeTechNoob. They were great to work with. I ended up having him print a bunch of stuff for me. If he is still printing I'd hit him up.
  15. cirodts
    are you okay with mojo?
