mandrake50
- Aug 13, 2007
The M106 need, in rough terms, around 0.4 watts (400 mw) to reach about 121 DB. A level that will damage your hearing after a short period of time. What are you doing with the other 3.6 watts. In fact the specs say that the OPTIMAL Power is 200 mw UP TO 4 watts. Nowhere is it stated that they are designed for 4 watts!! Only that amps from 200 mw up to 4 watts can be used.
The 10 watt figure is for extremely short term (200ms) . Longer than that will surely destroy the headphones! They are rated for a max of 130 DB, which they should get to at below 4 watts (approximately 3.8 watts).. That is not optimal for anything other than torture or nearly instantaneous ear damage.
It is misleading at best and possibly reckless, to say that any amp under 4 watts per channel is inadequate. That would leave out many, if not most quality headphone amps. Any quality amp that provides good clean power in the range of .5 to 1 watt into 50 ohms would be more than sufficient for very loud listening. Considerably less than that for people that value their hearing.
