Rulzux
- Mar 1, 2017
When you take the stock pads off, the cloth attached to the pads will come off with it. leave everything else the same (cloth covering the headphone driver stays).
thanks man!
Just a reminder: @Mishal and everybody else who's rather new to EQing - use an analysis panel to reflect the actual changes via EQ to confirm/estimate what's happening (available on Equalizer APO), always use a (negative) pre-amp option to avoid clipping if you're boosting something; or alternatively cut everything besides the part(s) you want to actually boost.
I wanted to share this because I think that Equalizer APO is a must for anyone running windows and would want to get the most out of his audio gear. You can also check this youtube of how to use it with Room EQ to calibrate/EQ a headphone, very informative and I am thinking of trying it to generate different profiles and calibrations for my headphones for different needs (movies, gaming, music). enjoy
https://www.youtube.com/watch?v=wmHAqh_HYT0
I think you can also use it as a plugin in players like Foobar and Jriver, although I'm not 100% sure on that.
I use JRiver as it has a windows driver that allows you to use ASIO or WASAPI for all sounds, music or otherwise. A great deal for $50. Plus you can use all of it's DSP functions such as room corection, EQ, and crossovers for all of your audio.
EQ APO is great. But doesn't it work only with the Primary Sound Driver? No WASAPI or ASIO support...
If using Foobar, another option is EasyQ (http://www.rs-met.com/freebies.html) and the Foobar VST 2.4 adapter (https://hydrogenaud.io/index.php/topic,84947.0.html)
I've done that using REQ Wizard and my measurement rig. I would measure the headphones, create a target curve, and have REQ Wizard match the response to the curve. I would then apply the same EQ settings into JRiver and have my EQed headphone work with any sound I listened to. It's pretty neat. As far as emulating different amps or DACs that's beyond me as I've never seen any of my DACs or amps make measurable changes, although they all sound different. So there is more at work than simply frequency response.
I know 2nd order distortion is considered pleasing, and tube amps have varying degrees of it, sometimes up to 2% at full output, which is a lot. 3rd order distortion is generally considered harsh, nasty, and grating. There is also phase, power reserves, instantaneous response, etc. Just look at all of the different types of DACs and amps available. They all try to do the same thing and yet there are a ton of different approaches taken by the designers who are trying to make the best amp/DAC possible for the price.
