- Oct 24, 2006
Thank you antdroid and GenEricOne.
My Spark arrived today, along with 14 other sparks. Monoprice accidentally sent me one case instead of just one amp, though they realized this not long after shipping it and let me know I would be receiving a few more than I ordered.
Also in terms of sound I'm hearing a lot of static or buzzing noise on my amp. I had the same problem with the Cavalli tube hybrid and it's not just random it's the same parts of songs (most parts unfortunately) so I need to figure out what the deal is. I thought it was a faulty tube in the hybrid, but since this is a solid state it can't be that. Is anyone else hearing it?
Since they sent me multiple amps, I've tried two of them with the same static sound. Using a monoprice dac....maybe it's the rca cable? But the fact that it can be reproduced makes me think it's the amp, but theres no way its suppose to sound like this
Well you have 13 extra amps to try....
I do not have any static issues with mine. Could be your cable or if it's bad part of a specific song, are you sure your recording is not just bad?
I use monoprice RCA cables (the really thick short ones). I have not had issues on either my MCTH or the LS.
Have you tried bypassing the DAC and just plugging the amp straight into the PC, just to rule out the DAC?
Lmao U gonna give them the rest back?I plugged in a third one and it seems to be working as intended. Good thing they sent 15 amps
