Chastity
- Aug 24, 2002
Yes I do, as I usually use Oratory1990 or AutoEQ as bases, then I tweak for my age and preferences. Looking at the FR of the Monoliths, and GL850, that flat region in upper mids / lower treble is rather evil. I made my own EQ based on charts, then I found the GL850 EQ on AutoEQ and I liked it. I also found out that Goldplanar uses that wonky mini-XLR wiring that Monoprice uses, so I guess we know who makes them. (The GL850 also shares the recessed XLR ports with the outer shell that the Monolith AMT have)do you correct to harman target?
This is my current tweaked EQ:
Code:
Filter: ON LSC Fc 105 Hz Gain 9.1 dB Q 0.7
Filter: ON PK Fc 3385 Hz Gain 6.1 dB Q 1.42
Filter: ON PK Fc 965 Hz Gain -3.72 dB Q 0.92
Filter: ON PK Fc 76 Hz Gain -3.3 dB Q 0.33
Filter: ON PK Fc 8567 Hz Gain 4.1 dB Q 0.9351
Filter: ON HSC Fc 10000 Hz Gain -1.6 dB Q 0.7
Filter: ON PK Fc 128 Hz Gain 0.8 dB Q 1.58
Filter: ON PK Fc 231 Hz Gain -0.7 dB Q 2.3
Filter: ON PK Fc 60 Hz Gain -0.7 dB Q 2.75
Filter: ON PK Fc 2167 Hz Gain -1.1 dB Q 5.43
