Dyjon54
- Jan 25, 2012
anyone own the
i have the panasonics and for $30 they would be very hard to beat...i have a list of things that i dont like about them but for the price they are exceptional..
the panasonics will be very good for your needs. A++on gaming and movies plus they are very clear and detailed in the mids and highs with heavy bass so r&b would do well.
it took me a while and a few more expensive headphone purchases to really enjoy these phones. they are uncomfortable to me for long periods(more than 2 hours) but that is inherent in the around-the-ear design more than a problem with the headphones. the cheap padding is the most annoying part and that can be replaced.
I haven't done any of the more complicated mods yet, but the three mods I have done have helped the sound-signature tremendously.
The first mod is the hardest.
1. remove the pads.
2. Pry open the headphones (there are four clips holding it in. These are the darker-grey ones. Not the light grey. Use a screw-driver or knife to pull one back and you should be good from there)
3. Remove this foam.
4. Reassemble your cans.
This second mod is the easiest by far.
1. Stuff paper towls in the ear-pads.
There is no step 2.
The last mod is equally easy.
Burn them in.
The difference with these cans is the difference between night and day.
If you think they sounded good out of the box... boy are you in for a surprise!
If you follow these three (relatively) easy steps, you should end up with some of best headphones that $30 can buy.
The bass will put just about anything with $100 of the Panasonic's to shame.
