Monolith M300 In Ear Planar Earphones
Jul 24, 2019 at 10:38 AM Post #558 of 660
First attempt M300, with bits I had around. Very comfortable, no complaints on fit. Second attempt, when parts arrive from China. Having had first attempt, with iSine also, so after first trials, will definitely be going headband with them both.
Aug 14, 2019 at 7:46 AM Post #567 of 660
Great! Do you have a link to the headphone/headband you used?
KitSound Metro Bluetooth £9.99 eBay. When you have dismantled them, measure CAREFULLy, where you need to cut the aluminium, I used a standard hacksaw, the horse shoe stem, fits straight into the aluminium stem. I used a bit or tubing, just to tidy things up.If not sure about cutting the aluminium, you could instead, fit a headband cushion, under the headband.
Sep 23, 2019 at 11:47 AM Post #568 of 660
I know most want to use these with wired solutions, I am trying them with custom earbuds(form fit off amazon) and a mmcx trn bt headset. So far not bad. It does get a bit fatiguing after a few hours. But they stay in and sound pretty good.
I am going to try to find a KitSound Metro Bluetooth alt in the US. Has anyone else found one?
