Monolith M300 In Ear Planar Earphones
post-13692535
Post #16 of 647
Saoshyant
Lenexa, KS
Lenexa, KS
Glad to see the project wasn't shelved. I suspect I'll be ordering at first opportunity.
post-13693172
Post #17 of 647
DrunkSaru
San Fernando Valley, CA
I've been trying to find more info on this as well with not much luck but I'm not going to bite on this one seeing how I just bought the MP XXX earbuds. If the trend over the last 2 years continue, there should be some good deals by Audeze on Black Friday and the iSine's have been out for a little while now so cross fingers and hope that maybe the iSine20 will go on sale to a price similar to whatever these M300's will be.
post-13693363
Post #18 of 647
Saoshyant
Lenexa, KS
Lenexa, KS
Perhaps the iSine10 will be at M300 price, but the 20 dropping to match the M300, which I'm hoping for 200 or less, seems unlikely. Would be great, but I wouldn't get your hopes up.
post-13693413
Post #20 of 647
Saoshyant
Lenexa, KS
Lenexa, KS
I should ask, how much do you think the M300 will sell for?
post-13696513
Post #22 of 647
DrunkSaru
$149 according to website:
https://www.monoprice.com/product?c_id=120&cp_id=12001&cs_id=1082707&p_id=24461&seq=1&format=2
Model 24461
Style In-Ear, Universal Fit
Transducer Type Planar Magnetic, Semi-Open
Magnetic Structure Toroidal
Magnet Type High-grade N50 Neodymium
Diaphragm Type Uniforce double side voice coil design
Transducer Size 28mm
Maximum Power Handling 3 watts
Maximum SPL >120dB
Frequency Response 18Hz ~ 50kHz
Total Harmonic Distortion Less than 0.1% at 100dB
Impedance 22 ohms
Dimensions 1.3" x 1.6" (32 x 40 mm)
Weight (per side) 0.48 oz. (13.5g)
post-13696522
Post #23 of 647
Levanter
Nice price, i'll probably jump in on these. Hope there won't be issues with their 1st version of the M300 unlike their M1060 which they had to release a V2 soon after to address the problems...
post-13696610
Post #24 of 647
kukkurovaca
They even copied the surefire earlocks, which is kind of hilarious. I wonder if (a) they're the same dimensions and (b) if they'll sell them separately.
post-13696700
Post #26 of 647
HiFiChris
Model 24461
Maximum SPL >120dB
Impedance 22 ohms
Seems to be a pretty reasonable price, especially if they managed to get the frequency response right.
I cannot really say I'm a fan of the cable (I'm generally not a fan of nylon/cloth-coated cables) let alone the design though. The rear vents look like effing camomile blossoms.
post-13696705
Post #27 of 647
leeperry
Galvanically isolated his brain
5 year warranty again?
post-13696879
Post #28 of 647
jant71
30 day money back and...
:smile_phones:
post-13696904
Post #29 of 647
manukmanohar
India
India
Anyone knows about this query, I was having:
Is it having an mmcx connector cable. If so, would a third party one with mic work.?
post-13696924
Post #30 of 647
DrunkSaru
If nothing changes from now till launch, yes for mmcx and
yes for the mic question.
Reactions: manukmanohar
