- Oct 14, 2013
Why not gold filled Brass ? Could they do so if you provide materialsI had these options at current supplier. I ordered some balanced covers and some full length covers.
Wow nice job!Hand made Pure Silver backplate !!!
Neither brass nor gold are as good for sheilding as copper, silver & aluminum.Why not gold filled Brass ? Could they do so if you provide materials
Did this give you more clearance for thicker caps up top?Don’t know about which one is good shielding, but any metal that can conduct, can shield against EMI and interferences. Ferrite beads can also help....different materials is more effective against some different interferences but whatever the case is
I can report back that I tried 3 metals on the back plate: Aluminum , Copper , Pure Silver
Somehow Silver has the best bass energy and improve Deep bass fidelity, density and decays while seems to also improve the airiness overall
It could have been placebo ....because this makes no senses to me. This backplate is simply a shielding on the back that conduct throughout the whole body....why would it alternate the sound performances while touching no where near the main PCB ground paths
Nope, it fit the same caps, just that you don’t have to modify and cleaning inside the plastic back-plateDid this give you more clearance for thicker caps up top?
The only logical explanations I have is that the Pure-Silver back plate must be very effective in absorbing “stray-Magnetic fields/currents” emitted by the Inductors being used by the Balanced output. It must be much more effective than other materials I have tried as listed (Copper, Aluminum).Don’t know about which one is good shielding, but any metal that can conduct, can shield against EMI and interferences. Ferrite beads can also help....different materials is more effective against some different interferences but whatever the case is
The inductors edit**, "may not" be shielded.
Looks to me like the stray vertical flux lines hit the metal plate, and are shunted (bent & following now into the metal ) , but an AC signal (music) would make the flux lines go the other way as well...So, the stray fields are not hitting and bouncing toward the other “inductors” and close by “components...
I was wrong there is less shunt in that specific metal because of low permeability or magnetic attraction.The inductors are not shielded.
They look like open core. So that pic would be correct that some of the flux lines are going up and hitting the top plate.
That's a different condition, than just having a simple plastic cover.
So that flux line that went into the metal, now reverses and comes out, maybe more so, from other flux lines that went into the metal from the other inductors and diverted ...
Creating a more efficient flow of flux lines that would instead have been lost in the air instead of shunted.
Since the silver has higher conductivity, it makes sense to have more effect.
Yet, this is purely my assumption (from my own experience with components), so I could be wrong.
Yes, that is correct, the shield has to have the ability to disperse the collected energies. Otherwise it becomes antenna and attracts the energies.I was wrong there is less shunt in that specific metal because of low permeability or magnetic attraction.
It is higher conductance would help any coil noise from the class D output filtering, so should have lower noise floors, with a higher conductivity sheild.
I also remember @Whitigir did not like covering the coils with copper tape, saying it actually increased noise, maybe because sheild wasnt grounded? Like the silver plate?
How about cutting tiny circles Of this TDK material, to cover & place only top middle of the coils?magnetic EMI sheets is the lowest noises but loosing out extensions details and energies. These are TDK noises absorb any sheets
It wont even help at the coils, unless you cover the whole plate which barely doing anything to the noises....very negligibleHow about cutting tiny circles Of this TDK material, to cover & place only top middle of the coils?
It can’t be, if so, the pure copper itself would have done the job. Beside, there is no grounding from the back plate toward the main PCB ground at all...it is only the extensions of the main chassis. The main chassis is already too much for grounding properties.....little more won’t matter. Case in point was that neither aluminum nOr copper did anything observableMaybe the silver plate is indirectly Making grounding the board circuits better...
