- Oct 14, 2013
The only logical explanations I have is that the Pure-Silver back plate must be very effective in absorbing “stray-Magnetic fields/currents” emitted by the Inductors being used by the Balanced output. It must be much more effective than other materials I have tried as listed (Copper, Aluminum).
So, the stray fields are not hitting and bouncing toward the other “inductors” and close by “components”, which in turns improve the performances ?
Shielded and Unshielded SMD Power Inductors First, the magnetic field generated by the shielded power inductor keeps the magnetic field within the inductor. It emits few magnetic fields outside the package and has a less negative effect on others parts that are in close proximity to it, therefore minimizing the coupling to other components or modules. In an unshielded inductor, some of the magnetic flux field is radiated outside. If a sensitive component or module is in close proximity to it, its normal functionality may be affected. Since the entire magnetic flux field is contained within the inductor, the power efficiency is higher. The inductor also contains less wire turns if it has equal inductance with the unshielded inductor. This results in the DCR being smaller for a shielded inductor, as compared to that of an unshielded one. If the DCR is the same for both the shielded and unshielded inductors, then this implies that the inductors utilize the same wire and winding turns. The shielded inductor should have a higher inductance value than the unshielded one. However, the inductance change versus the current curve will drop earlier because of saturation characteristics. This determines that the unshielded power inductor is easier to work with in a larger current.
if you read through this post carefully, you would know what I am trying to say here @Maxx134
keep in minds that I don’t even know if that would explain it. The performances improvements is observable, which you can replicate to observe. I am only trying to find the logical explanations since I observed the improvements
