- Oct 14, 2013
Yes you are in J version
easiest sign is to check if u have "Certificate" item at the bottom of settings. Only J has it. You need to restart to activate itHey do you know if this means I am in JP version now? can you please confirm
Yes I checked it said this
Model: NW-WM1Z
Series: NW-WM1 Series
Destination: J (0)
Sound pressure: 0 (off)
Means I am in japan version now?
how can i know if mine is japan?
u need to on a fresh install. otherwise no need.Do I need to rerun the dmp1.02 fw after I enabled the JP version?
Just updated to be more compatible to J region. Hopefully also compatible to Aus
Model: NW-WM1Z
Destination: J (0)
