Modifying WM1Z/A
Status
Not open for further replies.
Feb 28, 2020 at 1:54 PM Post #166 of 3,042
I have been able to confirm that none of the modified firmware installers nor the official Sony updater will run on macOS Catalina 10.15. They only run on macOS Mojave 10.14 or earlier.
Sony only documents support for macOS High Sierra 10.13 or earlier in the download link for the official updater. I guess that it does work in macOS Mojave 10.14 is a lucky coincidence.
So until Sony adds support for macOS Catalina 10.15 you need to have access to a macOS Mojave 10.14 system or heaven forbid a Windows 10 system.
Feb 28, 2020 at 4:02 PM Post #167 of 3,042
Feb 28, 2020 at 4:25 PM Post #168 of 3,042
Does destination code J support RMT-NWS20 remote?
Feb 28, 2020 at 5:19 PM Post #170 of 3,042
the option to connect bluetooth remote is present in region J
Thanks. No I'll be able to test destination J and keep my remote.
Feb 28, 2020 at 7:24 PM Post #171 of 3,042
I have found that if you run Mojave in VMware Fusion on a Catalina host that the Sony updater app will work. So if you have VMware Fusion and a copy of Mojave you have a work around until Sony adds support for Catalina.
Feb 28, 2020 at 7:46 PM Post #172 of 3,042
How to change your Walkman to Japanese Region and also Uncap at the same time
remember to restart after successfully change your Region
create a new folder named “Tool”
Download this Tool for Windows
https://www.dropbox.com/s/zxfbibs689ma3yq/scsitool-nwz-v25.exe?dl=0
Then this one
https://www.rockbox.org/wiki/pub/Main/SonyNWDestTool/open_cmd_here.bat
Then move both of those files into folder “Tool”
Then rename your “Scsitool-next-v25” into “scsitool-nwz-vX”
Then open the folder up and run this “open_cmd_here”. You will open command prompt
Then you will copy “scsitool-nwz-vX.exe H: dest_tool set J off” Please Pay Attention that your “H:” should be what your Walkman is shown on your windows. Mine show up as “D:” .
Then Paste this command into the command prompt windows and hit “enter”
You will see Successful messages
To make sure, you can check it by running this next command by copy and paste “scsitool-nwz-vX.exe H: dest_tool get”. Remember to change “H:”
Please copy only the line within “xxx” and not the “ “ itself
I just did exact procedures but I have no Idea if I am now a jp version says successful
C:\Users\AorusX5\Desktop\Tool>scsitool-nwz-vX.exe D: dest_tool set J off
Model: NW-WM1Z
Series: NW-WM1 Series
Destination successfully changed.
Please RESET ALL SETTINGS on your device!
Feb 28, 2020 at 7:49 PM Post #173 of 3,042
C:\Users\AorusX5\Desktop\Tool>scsitool-nwz-vX.exe D: dest_tool get
Model: NW-WM1Z
Destination: J (0)
Sound pressure: 0 (off)
Feb 28, 2020 at 7:58 PM Post #174 of 3,042
Can anyone tell me how to change the region using MacOS?
Feb 28, 2020 at 8:03 PM Post #176 of 3,042
Type this:
"scsitool-nwz-vX.exe H: dest_tool get"
replace the H: with your drive location
Yes I checked it said this
Model: NW-WM1Z
Destination: J (0)
Means I am in japan version now?
Feb 28, 2020 at 8:11 PM Post #180 of 3,042
Just updated to be more compatible to J region. Hopefully also compatible to Aus
Hey do you know if this means I am in JP version now? can you please confirm :)
Model: NW-WM1Z
Destination: J (0)
Status
