rolla
- Mar 29, 2007
maybe i'm missing something but when i switched cables on my 3's, they look exactly like they did when before. What exactly is the point of switching the cables??
Originally Posted by rolla /img/forum/go_quote.gif maybe i'm missing something but when i switched cables on my 3's, they look exactly like they did when before. What exactly is the point of switching the cables?? |
Originally Posted by blehmann /img/forum/go_quote.gif I approached this modification with a combination of skepticism and quiet desperation (yes, I know this is a bit much). I had become quite disenchanted with the super fi 5's in place of their much cheaper cousins, the Senn cx300s, and was on the verge of relegating them to use only in airplanes. This mod made all the difference: the accuracy, clarity, and headstage all came back. For this I am most grateful! |
Originally Posted by Pianist /img/forum/go_quote.gif Hmmm.... Are the wires in FS mod supposed to be connected with the 'L' and 'R' markings pointing backward instead of forward? Never thought it would make any difference, but it did! ![]() |
Originally Posted by IPodPJ /img/forum/go_quote.gif As posted way back in this thread, the mod to the SF5pros diminishes sound quality. If you can't tell, well, I dunno what to say, I'm glad it works for you. It makes more sense that it might be effective on the 3studio since they are only single driver IEMs... but when you start inverting the dual bores, the sound enters your ears differently and yields totally different sonic qualities (somewhat displeasing to my taste)... and with the Tri.Fi, forget about it, you can't do it... it totally ruins the soundstaging. |
Originally Posted by music065 /img/forum/go_quote.gif ...In addition to Ipodpj's comment regarding how the mod reverses the dual drivers configuration in your ear, this mod also reverses the L-R cables! I'm surprised I didn't see this point mentioned more in this thread... |
Originally Posted by epithetless /img/forum/go_quote.gif Since the cables are removeable (a core feature of UE earphones), either earpiece can be made to be "left" or "right" depending on how you plug the cables in. |
Originally Posted by stereophile /img/forum/go_quote.gif I see pros & cons regarding some users are saying this mod improves SQ, while others say it makes SQ worse. Now that some time has passed, can experienced Superfi.5 users tell us their opinion: do you prefer the SQ when wearing the 5's as orginally intended, or do you prefer this mod? Thank you! |
Originally Posted by epithetless /img/forum/go_quote.gif The cables need to be swapped along with the earphone housings. Since the cables are removeable (a core feature of UE earphones), either earpiece can be made to be "left" or "right" depending on how you plug the cables in. As for the other reductions in sound quality (muddiness, etc.), I wear my super.fi 5 Pros in the stock configuration, so I can't comment from my own experience...though I trust people when they say they hear a difference. stereophile -- I suspect, like many things audio, that it's up to user preference whether the FS mod is a good fit for you. There's certainly no harm in trying or reversing it (as long as you're careful with those cable connections... ![]() |
Originally Posted by konon /img/forum/go_quote.gif I loved the mod, better comfort and improved sound isolation. However with the mod I also experienced HUGE drop in clarity and sound stage. The only explanation to quality loss s is a reversed polarity. It occurs when you plug the wires with bumps on wire facing bumps on headphone. If you try to plug the wires with bumps NOT facing the bumps on the headphone - the sound quality is as same as with traditional way of wearing the headphones. To test the polarity you will need a poltes.wav file available along with explanation from http://www.d-and-d.com/mrivers/poltest.html It's ten seconds long, and mono--at the five-second mark, the polarity inverts. Original polarity signal (0-5sec) sounds more "bassy" than the inverted signal (5-10sec). Test it for yourself... -Alex |
