alecsus27
hi, can you guys please help me with a 'walkthrough' on disassembling the pc-350? i've only seen those small screws on the outside, but upon unscrewing 2 of them i still didnt find a way to get further. i am afraid to force /break something on the parts of the headphones, so please tell me which is the way to go (ive seen the photos and thanks for those, but they only start when the headset its already disassembled.
thanks.
oh, and an additional question: what if, instead of drilling holes in that plastic material, i would use a needle made very hot in fire(the other part of the needle i would pierce it in a cork, to be able to hold it)? i would probably only need to push a little bit, and there you go, the hole is done - not to mention there will be no more scrambles of plastic to go inside through the hole. problem is, might the extreme warmth from the needle degrade some sensible components on the other side? or aren't there any?
thanks again, i really need to try this modding, as i really dont like at all the weak bass (and trebble, for that matter) of pc-350, which ive only bought some days ago...
thanks.
