Sep 15, 2012 at 8:55 AM Thread Starter Post #1 of 5
FarhanR
Hi guys,
Ive been using M50s (Old model) for over a year now. They are good sound wise (a little bass heavy) but the comfort SUCKS. After wearing them for a few minutes, your ears get sweaty and paining. So i've thinking of the 2 below options are if they are strongly recommended
1) Changing the Ear cushions, below is the Amazon link, it doesnt specify if it can fit on M50s so i would like your opinion on them.If possible please post your links below. I can only hope that changing ear pads don't
http://www.amazon.com/gp/product/B0016MF7W2/ref=s9_simh_gw_p23_d6_i1
2) The Bass is a bit too heavy, i use them for Professional purpose and its a little problem since you dont get accurate sound. Is there a work around for it? Like is it possible too cut its bass a little?
Also, ive been secondarily thinking of jumping to Beyer Dynamics DT-770. I'd like your thoughts on the same too.
Thanks
-Farhan
(India)
Sep 15, 2012 at 9:29 AM Post #2 of 5
The DT250 earpads do fit the ATH-M50 but they change their sound in a significant way. They are also slightly smaller than the ATH-M50's original pads and this coupled with the clamp of these headphones could make them quite uncomfortable.
Instead, I found that it is best to simply sow a layer of cotton onto the original pads. The sound remains the same but they become far more comfortable.
Sep 15, 2012 at 9:35 AM Post #4 of 5
Just remove the earpads (they come right off) and sow a layer of cotton onto them. (around the doughnut shaped bit). As for decreasing bass, you might consider covering up one or more of the bass ports.
Sep 15, 2012 at 9:45 AM Post #5 of 5
Quite dont get how you did it. Did you thread them over your stock cups?
