dogears
just check my profile please - too many to list haha
Excellent looking cables willsw. How do your cables compare sonically to the M&J? They look more heavy duty, but stiffer and heavier.
As you stated, the GL2 requires care to find a properly fitting replacement cable. There is very little extra room in the wood earcup. Found a Radio Shack Auvio 2m braided cable that plugs in. Bought it as a back up. Doesn't have quite the effortless highs of the stock cable.They also had a very skinny extension adapter for phones that is about 2" long. That allows the use of fatter cables. Are you going to stock your cables or the original M&J?
