LarsHP
I don't have big ears, no. However, I don't think the mod takes that much space away from the inside considering we have to stretch the pads to cover the HiFiMan headphone diameter which increases the width.
Being 6' 5" (1.95 m), I've got a head and ears to match, but more to the point, I did not mount my pads by stretching them over the mounting rings, just adhered them to the rings. I did stretch them out a bit, but the interior tends to go back to its natural oval shape.
I put the old HiFiMan mounting rings inside the HM5 pads, so my pads probably get much more stretch than yours. And I'm 193cm tall BTW...Being 6' 5" (1.95 m), I've got a head and ears to match, but more to the point, I did not mount my pads by stretching them over the mounting rings, just adhered them to the rings. I did stretch them out a bit, but the interior tends to go back to its natural oval shape.
I'm betting that there's audible differences between an oval and a more rounded shape, FR curve-wise.
And I bet all the oval angled HM5 pads revert to a more oval than round shape in time, I don't think stretching for a day could change the shape permanently, even with the standard HiFiMAN mounting ring, as I've got that stretching the pad all the time, but it's still oval
Sure.
Yep, absolutely. Nope, that's why I put those compressed air cans in them when I'm not using them. May stop that practice, though, as the oval shape is more ergonomic (as noted). With the HE-560, the key to comfort is the right tension in the spring steel headband. Fortunately, it's really easy to tweak it in either direction. Like the pads, the headband tends to revert to tighter over time, though not as quickly.
Measurements are fun to look at, but beyond my ability. Given it's down to total system synergy and what sounds best to any given listener, I just roll and tweak until I get what I want. I'm definitely not saying it's extensible beyond my head and rig.
Yes, real leather is definitely stiffer in relation to pleather or vinyl. But this leather is wonderfully soft and supple, and gives plenty. The HM5 pads are thicker in general compared to the stock pads, so it stands to reason that one may need to spread the headband a bit to relax it. Or not. Never know 'til you put it on your head. When I first put the HE-560 on, with stock FocusPads, it literally was a painful experience. Then I read a post (probably by jerg) about how the headband could be bent out. That spring steel is some serious schiit!
re: seal, yep, the pleathers seem to seal better. Also, the oval shape, being more ergonomic, seals better with the leathers. I think the leather softens up as it heats up (15 min. or so), and seals better over time. That, or my head just gets used to them in that time, but I'm pretty sure the seal improves. Round vs. oval... more room with the former, better seal (and thus bass, at the very least) with the latter.
HE-350 with Denon pads, HE-400 and HE-500 with Brainwavz angled pads.
Quite a lovely set! Any problems whilst installing?
I've been using Brainwavz angled pads for my HE-400 for about 1,5 years...initially I trimmed the rings outer edges to fit the pads...but I found out a bit late that by stretching the hell out of the pads you can fit the original rings without trimming. No probs also installing them on the HE-500 (got these after selling my LCD2F).
For the HE-350...no probs fitting Hifiman rings on Denon pads...nice fit!
FYI, I'm using 3D printed rings on the HE-350.
http://www.thingiverse.com/thing:1784520
