Mission: Replace the HiFiMAN ear pads with other brand ear pads
Nov 9, 2013 at 3:03 PM Post #423 of 756
Wonderful - thank you. I might buy some for my upcoming HE-400 purchase..
I personally use Alpha Pads on my HE-500 and while I found them to improve the soundstage and imaging of the HE-500, it's at the expense of bass but you do get sweeter, more forward mids with a touch softer treble compared to the velours. They are extremely comfortable and they fit without so much of a stretch.
Though when I noticed that the bass has been tamed down, I did some modifications to the pads to lift the bottom end a bit.
I was a bit inspired by the Jerg/Modulor pads.
First of all, I cut off a tiny portion of the lip for easier mounting to the plastic rings.
Second, I reversed the pads so that the underside is exposed and I cut eight roughly equidistant holes on it.
The results aren't exactly pretty because I didn't have an exacto knife lying around so I used scissors.
After the mods, low end frequency is a bit more present without hurting the soundstage but keep in mind that this is for the HE-500. I have no idea for the HE-400 though and again, I stopped at eight holes but I don't know what the effects will be if I add more. I will stay at eight for the meantime.
Nov 9, 2013 at 6:44 PM Post #424 of 756
Interesting. The damping holes in my mod are not for the sake of changing the bass at all, they are for smoothing out the 2kHz - 7kHz region as well as for reducing energy around 1kHz.
But that's with a LOT more holes cut out at the bottom, and is for the pleather earpads which are much shallower than the alpha pads and which have different kind of foam/covering materials. So what you did may not have produced similar effects at all.
Nov 9, 2013 at 7:04 PM Post #425 of 756
Well you need to take my words with a grain of salt. What I hear is that there's a bit more bass coming out but then objectively, I don't exactly know if this mod really upped the bass or has other effects on the FR.
I put those holes because when I saw the HifiMan pleathers, there were some damping holes as well so I thought why not put some on the Alpha Pads and see what happens.
I did notice after I cut those holes that the sound did slightly change around the low frequency region. Maybe cutting holes on the Alpha Pads makes it easier for bass to travel through the earpads.
Nov 9, 2013 at 7:06 PM Post #426 of 756
The 4 tiny pin-holes on the stock pleathers don't do much damping I'm afraid. I think they are more for the sake of making the earpads easier to wash - since if they are fully sealed or almost fully sealed without those 4 holes, they'd be a nightmare to dry after washing with water/soap.
Nov 9, 2013 at 7:26 PM Post #427 of 756
Didn't know you can wash earpads...
Nov 9, 2013 at 7:43 PM Post #428 of 756
Oh you can, and you should, to maintain their longevity. Just warm water, mild soap, soak + squeeze thoroughly a few times, scrub the cover material clean, then squeeze as dry as you can in (paper) towel, and leave to air-dry for 24hr.
That's with non-leather earpads (pleather/velour/whatnot) though. With genuine leather earpads, it might not be a good idea. Instead, just wiping the leather thoroughly with a damp cloth, air-drying, and applying a hypoallergenic leather protective product might be the best course.
Dec 1, 2013 at 5:10 PM Post #432 of 756
So what is the verdict on the best non-jergpad pads on the HE400 for us non-crafty types?  Is it the vegan pads or the stock velours?  I want lots of comfort that doesn't negatively impact the sound too much.
Dec 1, 2013 at 5:34 PM Post #433 of 756
I've tried the stock pleather, velour and J$ Beyer pads and the latter wins big time when it comes to comfort. Soft and a snug fit. I think they might cause a little more brightness than velours but far from sure. Other guys will know. Also have some Alpha pads coming in so I can compare the two soon.
Dec 2, 2013 at 8:58 PM Post #434 of 756
Please post your impressions.
Any others tried the microsuede pads from Audeze?  I'm really interested in those but need to see more opinions before I spend $100 on pads.
Jan 4, 2014 at 4:17 PM Post #435 of 756
I gotta say I enjoy the stock pleathers minus the foam inserts or the stock D2000 pads. I may try the foam inserts on the D2000 pads as well. So far both produce the best bass and overall sound to my ears. The D2000 pads are probably the most comfortable I have tried so far!
