Bogatyr
- Jan 22, 2012
Has anyone found alternative pads for their Hifimans that they actually ended up sticking with?
Stay updated on Audio-Technica at their sponsor profile on Head-Fi.
The LCD3 pads definitely tame the bass down, probably because of the distancing from the driver. It's more mid-forward and open sounding than velour pads, at the expense of bass. Therefore I would not really do it with HIFIMAN headphones unless maybe the HE500.
It's definitely a smooth-sounding set of pads, but I didn't dig it too much with the HE500s.
Aha, well they definitely sound even worse on the HE400/HE6 by default (not on my HE6 rig though). That's why I said maybe better on the HE500, haven't tested it on that headphone myself.
J. Lawton angled pads
I think you mean either jmoney or M.Lawton (Lawton pads). There is no j.lawton pads that I know of. I tried both of those pads but they sucked out the bass and were kinda too small. I believe 90mm where you looking for 103.
I found that the he-500 are kinda the opposite of most headphones where thickness and angle are concerned. The thicker the pad, the more aggressive the angle on a pad the more the bass seems to float away. L-3000's are 100mm and not as thick or angled as most of the pad options out there but supremely soft and way more comfy than the stock pleather and velour hifiman pads.
SQ wise not a whole lot of change from stock, which was for me a good thing. I put them up against stax 02, denon, Lawton, jmoney(denon), and audeze lcd-2 leather. To me the L-3000's were it. Also, if you had jmoney, was it jmoney beyer or denon? To me the denon variations are too small, work but barely and audeze too big, kept floating around. Stax was pretty darn good but even those messed with the sound in a way I did not care for.
Fostex th-600 pads are the bees knees.
What are your impressions of them with HE-500?
Where can one purchase them?
How much do those things cost?
