Grounding the inputs means shorting the ground lug to the signal lug in the RCA jack. Its like the minimum position of the volume pot, where essentially the wiper of the pot is shorted to ground. But because of production tolerances, its only "almost" shorted, not completely shorted, so there is some signal still present.
The reason I ask is because of your comment that the hiss increases as you rotate the volume pot. Since the amp components sit behind the pot, then increasing the volume should not increase the hiss at all. So I suspect that you are hearing the source hiss.
Okay. I did some experimenting.
A couple things:
1) My RCA inputs are always noisier than the GrubDAC inputs (when off).
2) If I don't ground the RCA inputs and turn up the volume all the way max, I get a buzzing sound in the left channel (and only really noticeable in the left channel). This is interesting, because I've always thought my pot had a channel imbalance between leftmost turn and ~8-9 o'clock (where the left channel would be louder than the right).
3) If I ground the RCA inputs and turn up the volume, the hiss will be less evident, but still more than when I have the GrubDAC selected (and off).
4) With the DAC selected the hiss does increase with the volume, but only slightly. Most of the hiss is still present at zero volume (maybe about twice as loud going from zero volume to max volume).
5) with the GrubDAC on and volume to max, I definitely hear computer noise, as it gets worse when I move my mouse. This is not something I hear at normal listening levels.
6) With the RCAs selected and the inputs not grounded, most of the noise/hum (mostly evident in the left channel) (not the background hiss) is attenuated when I put my hand on the metal case of the amp, then completely disappears when I lift the amp off my desk. My case is isolated with little rubber feet, and placing some paper underneath the amp doesn't get rid of the "lift" effect. I suspect my tubes are slightly susceptible to vibration.
So while I can definitely hear some input noise depending on what it's connected to, the "hiss" I hear with Grados is definitely coming from the amp. I don't think it's a ground plane issue, because my star ground is linked to the case, which should be good enough. I have a lot of excess wiring; could that be a major contributor to noise/hiss?
