tomb
Member of the Trade: Beezar.com
- Mar 1, 2006
It's the tracking error in the Alpha pot. The Alpha pot is not built for very low-level precision volume adjustment. One of the reasons for using the input resistors is to "level" this trait out, as in the "low volume" progressively extends over a greater range of volume travel. So, you might try higher-value input resistors if this continues to bother you.
Originally Posted by PJPro /img/forum/go_quote.gif Actually, I may have just identified a problem with my amp. If I turn the sound right down and slowly turn it up, the sound comes out of one headphone while the other is silent. As I turn it up, the other channel gradually gets louder (but always quieter than the other) until it gets to normal listening volume (not that loud) where it appears to have "caught up". I some ways it's like a balance knob being turned from the left to the middle but getting louder at the same time. If I turn it right, right up the sound stays fixed in the middle, rather than continuing on past the middle. I haven't noticed this until now because I don't really fiddle with the volume once it's set. The amp had warmed up and had a couple of hours under it's belt that day (50 hrs total) when I discovered the issue. Any ideas or is this normal for valves? |
