cegras
- Nov 26, 2008
I've been lurking in silence for forever for the PCB kit. I am so totally in it D:.
Originally Posted by sachu /img/forum/go_quote.gif All that the heatsink mounting kit does is insulate the drain of the MOSFET from the heatsink. most MOSFETs have the tabs shorted to their Drain. The mounitng kit comes with a mica insulator which goes inbetween the MOSFET tab and the heatsink. Then you take the small plastic washer which goes into the mounting hole of the MOSFET through which you wil put the screw. You need this plastic washer without which the screw would short the heatsink and the MOSFET tab. |
Originally Posted by Yaka /img/forum/go_quote.gif woulda thought first come first serve makes more sense than anything else |
