Folks,
I'm looking for a new amp for my phones, and I think the micro ZOTL2 may be a good one to consider, but I have a few questions...
I've read all the posts (except the somewhat frenetic posts of the Mojo guy, which seemed out of place here and should have been in a different thread).
I'm currently running a Fiios X5 into a Lyr2 to a new pair of HiFiMan Edition Xv2 phones. Before that, it was into a pair of HE-400i phones.
I just purchased a Metrum Musette to put into the stream as the DAC, and I wanted to upgrade the Lyr2 to something a bit better, and was thinking of the Mjolnir2 because it uses the same tubes, which I can then carry over to them (I have some great NOS Siemens in the lyr2 ATM).
Anyway, I have been reading the posts on this new amp and am very impressed with the discussion and overall feedback, along with the reviews I've read, so I thought it may be a good alternate.
The New 's' version is a bit of a stretch for me, as I was hoping to keep it around $1000 or so. Not sure what it cost during the Massdrop promo, but it probably would have been able to talk myself into it at a discount. Too bad I missed it...
Anyway, I need some thoughts on the new 's' version vs. the older version. Since they are supposedly similarly sounding, is there a compelling reason to choose one over the other?
It seems that I can get a 'tweaked' HP amp in the 's' version, with NOS tubes, etc., but at what expense? Does the more limited tube selection present a drawback?
While I'm not a huge tube roller, I will happily do some, so I am wondering if I should go for the non-'s' version in favor of doing some tube rolling.
Beyond that, are there any other compelling differences I should consider?
Thanks,
---Michael
I used to own both Mjolnir 2 and the MicroZOTL 2. After getting the MZ2 I sold my Mjolnir 2 immediately. Both of them are good and transparent. I also have friend who listened to both and decided to keep the Mjolnir 2, so it might be a personal taste thing.
What I can tell you is that Mjolnir 2 is a more towards solid state amp while MZ2 is more like a tube amp in some way. Look at the THD and you will know. Usually tube amps have a higher THD. But specs are not the only thing that matter to the sound. I would suggest you listen to both before buying. If you plan to go to speakers in the future then MZ2 should be your choice.
