But back to the topic of the mZ2...
[COLOR=FF0000]mZ2 upgrade anyone?[/COLOR]
I've been getting so many emails off thread for mZ2 upgrades, so here you go...
I talked things over with Dr. Blue and we're going to do a comparison of upgrades where my mZ2 gets totally stripped down and premium parts and Dr. Blue's mZ2 gets upgraded with the highest value parts. Likely Dr. Blue won't want me to strip his mZ2 down as far as mine.
Then Dr. Blue is going to compare each upgrades, from stock to high-value to insane, and do reviews all along the way.
After Dr. Blue, the fully upgraded mZ2 and first production Illuminati power supply will be going to Dr. Jazz and Kevin Heine to review for different headphone magazines. Then this insanely upgraded mZ2 will be at RMAF. After that I may put it "on tour" to any of the Head-Fi group that want an in home audition.
If you want to get in on this DIY party, you'll need the following tools (come to the dark side...we have cookies):
1. Soldering gun, soldering gun cleaner, flux, and solder.
2. De-soldering gun and de-soldering tools.
3. Wire cutter and wire stripper...could be one tool.
4. Needle-nosed pliers...smooth if possible.
5. Medium point Philips head screwdriver.
6. 7/64" Allen head driver to open the top of mZ2.
7. 5/64" All head driver for volume knob and 1/4" jack)
8. 17mm open end wrench for the inside nut one the power switch
9. 11mm open end wrench for the Alps attenuator and binding posts.
10. 5/16" open end wrench for the input selector switch.
11. 13mm open end wrench for the RCA jacks.
Well, that's all I can think of for now...I have no doubt something else will come up...it always does :confused_face:
Keep in mind that those are the wrenches I had that seemed to fit - for all I know your mZ2 uses slightly different parts (I've heard there are a few incarnations). I'm sure you get the idea: you need a set of both metric and English open end wrenches.
A basic principle of upgrading performance of any component: "less is more."
First I'm going to show you how to strip unused features, such as the binding posts, second input, and power switch, as well as separating and isolating the input(s) from the outputs and the signal from the power.
This is a no cost upgrade.
Here is a photo of my mZ2 with the top and face plate removed.
In order to do a proper job of simplifying the wiring you need to remove the face plate and remove the connector, button, switch, and attenuator, to gain access to the wiring. You also may want to remove the locking nuts from the RCAs and binding posts to get better access when soldering/de-soldering wires from them.
Note that my mZ2 is sitting on a piece of soft thin foam...a 100% cotton towel is also good.
Notice my removed parts are organized into zip bags. I find these better protection if you are clumsy or have children and/or cats.
[COLOR=0000CD]Parts you can order today for upgrades I'll cover next week.[/COLOR]
One of the biggest bottle necks in your mZ2 is the Alps Blue attenuator.
I'll be spending about $200 on a Goldpoint stepped attenuator.
http://goldpt.com/
If I had only $200 to spend upgrading my mZ2 I would spend it on this stepped attenuator - yes it is THAT good.
The stock mZ2 has a 50K ohm Alps Blue conductive plastic element attenuator...let's call it Toyota level performance (best value) .
Just for perspective, you can buy a similar Alps Blue attenuator on eBay for about $20.
I happen to have a 10K ohm TKD conductive plastic element attenuator in my spare parts bin..almost identical in construction to the stock Alps Blue...let's call it Lexus level performance (better performance - good value).
I'm going to install that TKD attenuator in Dr. Blue's mZ2 so that he can compare it to the significantly more expensive Goldpoint.
I paid about $50 for that TKD attenuator and I almost fell off my chair when I saw the latest price online was $85!
Certainly a bit less of a value, but roughly half way in price between the stock Alps Blue and the Goldpoint.
It will be interesting next week when Dr. Blue compares them
Here's a couple of my favorite places to get connectors, wire, attenuators, and small amounts of shrink, braided coverings, and shielding.
Mike Percy usually has good prices, he is very helpful and knowledgeable, but his website is just a page with a downloadable PDF catalog. You have to copy/paste the model numbers from his PDF catalog into an email and he sends you a PDF invoice you can pay with PayPal or CC. Not too user friendly, but Mike has some of the best exotic parts that few others carry and among the lowest prices you'll find. You can also trust his opinion - he does this stuff and knows first hand how this part performs vs. that one.
http://percyaudio.com/
VH Audio is my other favorite. I could say the same things about Chris Van Haus as I did about Mike Percy and more. Chris has several great "recipes" on his website for things like high-value DIY interconnects and power cables.
http://www.vhaudio.com/
Both Mike and Chris sell some of the exact brands and parts but each has their specialty parts.
For example, I'm going to rewire my mZ2 with VH Audio's 24AWG UniCrystal OCC high-purity silver wire in cotton insulation that is $8.99/foot. I'm going to end up spending over $100 on the hook up wire alone.
Both Mike and Chris have quite an assortment of wire at all different price points that you can use.
Here's a link to some high quality mil spec or aerospace surplus silver plated copper Teflon covered wire on eBay that is the high-value wire upgrade option.
http://www.ebay.com/sch/i.html?_from=R40&_trksid=p2050601.m570.l1313.TR0.TRC0.H0.Xsilver+plated+mil+spec+wire.TRS0&_nkw=silver+plated+mil+spec+wire&_sacat=0
Now comes the question of "what value" attenuator?
Most common in the audiophile industry is a 100K ohm attenuator so that nearly any source will have decent bass.
Of course the higher the value the more veiled and distorted the sound due to something called "Miller Effect."
I normally use a 10K ohm attenuator, but I know that whatever DAC I'm using has a strong enough output stage to drive such a low impedance. You can't go wrong with a 50K like the stock mZ2 comes with.
As for connectors, I'm a Furutech fan.
The stock mZ2 comes with what appears to be some rather high-quality CMC gold plated machined copper RCAs and binding posts. I consider these to be a very high-value connector and I would not recommend upgrading them unless you've already decided to put in some expensive hook up wire and an expensive attenuator.
I would consider Cardas to be a bit better than the stock CMC - possibly not worth spending the $$$.
I would consider Furutech, XHadow, and Eichmann to be notably better than the stock CMC RCAs and binding posts (and considerably more expensive).
I wouldn't recommend upgrading to any of these premium connectors unless you also got the Goldpoint or a similar premium stepped attenuator. Don't fall for those cheap stepped attenuators on eBay - you can't get a decent stepped attenuator for much less than about $100 in parts.
Another important thing is the size of your attenuator - I know both the TKD and Goldpoint will fit comfortably inside the mZ2 chassis. Some of these large stepped attenuators and motorized attenuators can be quite large and might not fit. Also motorized and remote controlled stepped attenuators always have slightly lower performance than similar manual ones. Power = noise.
So get your tools together...get your parts lists together...order some of the parts.
Tomorrow I'll be stripping down my mZ2 with that "no cost" upgrade and giving it to Dr. Blue to find out if he can hear any difference between the stripped and stock mZ2. Next week when my attenuator arrives I'll be upgrading the attenuators on both mZ2 and giving them to Dr. Blue to review.
More to come :atsmile:
