upstateguy
- Dec 20, 2004
Sorry I have not answered yet.
V-Cap sound has improved noticeably. Basically, the two capacitors have cost me about $ 132 without transport, but it was worth. The differences with the stock capacitors are especially visible at the level of transparency, texture, sound separation and resolution. The sound is open ... Before instaling V-Cap capacitors, I compared Havana with a Dyi converter of a friend and I noticed something that Havana sounds dark on medium and high frecvents. Transparency! Even the Lavry DA10 I liked more than Havana in this chapter. As vocal, Havana is superior without question, but classical music felt differences. Lavry have a brighter sound.
After about 100-150 hours of listening to mount V-Cap capacitors felt a change in the sense that I liked Havana increasingly more. Same effect as when I changed the tube (with WE396A).
I use Havana with a solid state amplifier DIY "eXStatA" based on discrete circuits and a pair of electrostatic STAX SR-404LE "Limited Edition". At this level can honestly say that she felt any change in sound: which may come from the output capacitors, tube, power filter, interconnections,...
Just curious: if you can't go back and A-B it to the original components how do you know that the V-cap sound is improving or is even better, maybe you're just getting used to it over time? <--- just asking
Did you make any recordings of the original sound that you can compare with the new V-cap sound? http://www.libinst.com/Audio%20DiffMaker.htm
