Meze Audio LIRIC - The portable isodynamic hybrid array headphone
Apr 3, 2025 at 7:25 PM Post #1,591 of 1,601
I recently compared Liric 2 to Sony MDR-Z1R and Denon HA-D5000, the bass is D5000 > Z1R > Liric 2.
Liric 2 is weaker and less quantity. If one doesn't compare, Liric 2 itself sounds good actually.
I have the Denon AH-D9200 that I love, it doesn't have the finesse of the Liric 2. The Liric shines with well recorded albums, I play CD or SACD exclusively, but doesn't do too well on poor recordings and the Denons can really pick out the vocals on dynamically castrated albums. Horses for courses with both of these headphones.
Apr 11, 2025 at 11:27 PM Post #1,592 of 1,601
I'm done with the abysmal performance of Fiio Btr7. The battery is so tiny, it powers the meze liric og for 2 hours before it needs a charge, on 4.4 balanced output and bt on.
Can anyone here recommend a good dac or dap that can power the meze liric for 10+ hours?
I don't really need a dap, but if that's what I need to get to get a longer battery, I might just do that. I'm looking at ibasso dx260, but I'm also tempted to try a Walkman. Or a good dac with proper battery.
Also I need 4.4 balanced outputs.
Any help will be appreciated.
Very late response, but the Lirics sounds incredible with the Chord Mojo 2 in my opinion.
Apr 18, 2025 at 7:09 AM Post #1,593 of 1,601
Has anyone had any problems with the pads on their Liric II? I took mine off today to measure their backs and noticed that the material at the back has fused with the plastic behind them and pulled patches of it away. It's a bit hard to describe but you'll see what I mean from the pictures.
Apr 18, 2025 at 7:47 AM Post #1,594 of 1,601
Yes. My left cup is stuck firmly, I cannot budge it. The right cup comes off after a little persuasion and looks the same as yours. I may photograph mine and e-mail Meze, it looks like a glue problem.
Apr 18, 2025 at 7:49 AM Post #1,595 of 1,601
Contact Meze, mines Dont have this issue after a year of everyday use.
Apr 18, 2025 at 7:52 AM Post #1,596 of 1,601
Yes I was thinking too that it's glue seepage either from the cup or that plastic base beneath it. Sorry to hear that it's not a one-off. Mine are still in warranty via HeadAmp so it's not the end of the world for me, though the shipping costs are pretty rough from my... end of the world.
Apr 23, 2025 at 12:48 PM Post #1,597 of 1,601
I've got in touch with Meze and I'm about to ship them back with DHL arranged by Meze. It took just 24 hours for them to respond to my e-mail. They will be repaired and sent back with no expense on my part. Can't fault that for customer service. It may be worth you getting in contact with them. Here are images of mine, only one cup bearing in mind that I cannot even shift the left earpad.
I'm going to buy a second pair of Meze, either the new Poet or the Empyrean 2 depending on what the finance manager says I'm allowed. This quick response from Meze has given some encouragement for another one of their products.
Apr 23, 2025 at 9:21 PM Post #1,598 of 1,601
This appears to still be a current issue—I have a pair of just purchased Liric II I won't even attempt to remove the earpads for, as I'm sure they are stuck on there and will look the same if I attempt removal. On the other hand, I have a Poet where the cups come off as they should with very little pressure necessary for removal.
Is there anyone who is NOT seeing this issue with perhaps different production batches? I love the sound out of the box already, and want to love these, but I’m concerned about having to send them in to Meze at least once to correct this issue when pad swapping.
Apr 24, 2025 at 2:43 AM Post #1,599 of 1,601
I'm glad to hear that. I'm in touch with HeadAmp, where I bought mine - hopefully the return process will be this easy.
Apr 24, 2025 at 3:22 AM Post #1,600 of 1,601
I'm not foreseeing any problems with sending mine back, certainly at Meze expense and I'll let you know how long it takes. If you are in the US then I don't know if DHL will do a pick up as they have stopped deliveries from Europe to the US because of you know who but I would certainly get in touch with Meze about the problem.
As you have the Poet already is there a fairly significant difference, other than the open factor, that makes a worthwhile difference between the Liric and the Poet?
Apr 26, 2025 at 2:00 PM Post #1,601 of 1,601
I think it's easy to initially consider them something like a 1A & 1B, but they are different flavors to the Meze house sound. Do keep in mind, anything hereon is my opinion, and will not be described entirely analytically. I would also not refer to either of these headsets as analytical in nature. My testing on both was done with the same 4.4 balanced Meze Furukawa copper cable.
The Poet would best be described as gentle, sweet, smooth & forgiving.
Liric, while still smooth, is a bit more aggressive and darker, with more emphasized bass.
Poet will take a track and smooth out every note. High cymbal crashes do not overstay their welcome. Bass is present in quality, but not quantity. You will hear what you are intended to hear, and not any more--however, this also seems to be a more source-dependent headphone than Liric. The inherent qualities of Poet remain the same regardless of the source, but you can more easily tune to your liking (sans EQ) with different source pairings. I would consider the Poet a Meze-sweetened version of the Sennheiser HD800 (original, I have no experience with newer iterations)--but with the caveat that the soundstage doesn't open up much more than Liric. It is wider, and deeper, but it is the most intimately staged open back I've experienced. Jazz and vocal-oriented music sound fantastic.
Liric will hit you with bass much harder, and treble has a bit more harshness. Rock & metal are much more enjoyable with the Liric. I don't feel that the bass ever becomes too much, but I would say where quantity is a bit higher, quality is lower--Poet makes the bass musical, but less filling. Vocals can be a little more grating, because of tighter sound staging due to the closed back nature. My feeling is that these closely match the Sony MDR-Z1R, as a planar equivalent.
Comfort-wise, Poet is the one that sits most comfortably, but needs to be handled more delicately due to the Dan Clark style floating headband system. Liric's headband is much more rigid, but not uncomfortable. It does feel a little heavier. Liric, and the case it comes with, are better suited for portability.
I'm sure I've missed some good A/B comparisons here. But ultimately, to answer the questions if there's a fairly significant difference--I think it's significant enough to consider them complementary. I picked up the Liric as I loved the sound of the Poet, but my girlfriend did not when I was listening to music at night. I also did not like Poet for my heavier/denser music--sometimes I do want a little bite, and Poet will not bite at all. Neither one will be an all-in-one option, as far as I'm concerned--I like both sound signatures enough to keep both.
For a more "audiophile" oriented version of what my feelings are, I suggest this review from Headfonics.
In regards to my previous issue with the earpads, I contacted Bloom Audio (who I purchased them from) and they contacted Meze for me. Meze will directly send me a replacement without the issue once Bloom receives the Liric I'm sending back to them (with a prepaid label) and confirms the defect. I find this to be great customer service from both companies and a solid resolution for my particular case. I'm curious how Meze will handle shipping, however, due to the DHL block in effect for products over $800 value.
